After much adieu, And so it begins...
#41
Nam Labrat
Received 4,225 Likes
#44
Winter Deadline Approaching:
Transmission is drained...
Parts are painted and greased...
Parts are attached...
More parts are attached...
Motor is installed...
New stainless steel fuel line...
Exhaust is hooked up, all copper gaskets...
Driveshaft installed...
I build a new stand for the body...
#4 Mount being repaired...
#4 Mount curing...
What remains of the seatbelt reinforcement plate to rocker channel is removed...
The replacement will be fabricated from heavy gauge A36 steel...
The first A36 components are designed...
Cut...
The area is prepped...
I weld the reinforcements...
The reinforcements welded...
A before/after reinforcement...
Rocker channel repairs are designed...
Cut and marked...
Cut some more...
Modified...
Cold forged exactly to spec... ready to weld in...
I will keep you all apprised, next I shall weld in the rocker channel repairs, weld in the seatbelt reinforcement replacement, paint all of the underbody metal, and put the body on!
#4 Mount curing...
Cut...
Cut and marked...
Cut some more...
Modified...
#47
Update:
All of the exposed underbody metal is painted with POR-15 and the new urethane mounts are JB-Welded into place...
Tunnel insulation installed...
Final preparations are made...
The moment of truth...
Success!
Reinstalling the shifter ****...
Painted POR-15 above all 8 new mounts...
All 8 mounts are bolted down...
A rare look at mount #8. No caged nut, a foam pad with a washer and large 19mm nut...
Starting the front end...
Ready for assembly...
Good morning...
#50
Update:
The work continues...
Replacing my original "silver" seatbelts, and installing water diverters...
The new water diverter and seatbelt before putting the sill plate on...
Replacing the header bar...
Bonding the new header bar...
Replacing the metal supports. Someone had badly patched this corner at some point in this cars life... I just hope it wasn't the factory.
The front metal is ready...
More to follow, soon will need to fetch my radiator out of the attic
#51
Nice progress, How's the back? Don't worry, gain some weight and grow old it will get better.
Good luck, great to see 20yr olds into c3's I tell my wife it's not a young mans car,glad you are making me a liar.
#52
Update:
I finished the car a year ago and have been enjoying driving her ever since! The last step is a professional paint job...
Please enjoy these year old pictures of the final steps. Life took hold and I got busy and left the story unfinished, sorry!
Power steering...
High pressure lines...
Got the radiator and fans out of the attic...
Radiator and fans in, assembling the front bumper...
Bolting it all together again...
Bumper installed...
Gassed up, battery installed, took her for her first drive in nearly 3 years...
Out and about...
Moved to my own place and got her her own garage...
Parked at my new place next to my bike I got three months ago...
Well that's it for now, I will post some pictures after I have her professionally re-painted... and I still have plans to mess with the motor more...
Power steering...
Bumper installed...
Out and about...
#53
Update:
Power steering...
Bumper installed...
Out and about...
Power steering...
Bumper installed...
Out and about...
#54
Good job and hats off to you for the perseverance!
#55
It appears like the free image server I used has deleted/moved all the most recent pictures! I will edit the thread and get them re-installed again when I get the chance.
Thanks everyone, the car is most enjoyable and feels brand new again!
