Exhaust system picture thread. Post your X-pipes, duels, mufflers, h-pips//pictures!!
Nam Labrat
Received 4,230 Likes
Brace yourself.......Harley Davidson mufflers for now......
the exhaust is original from the manifolds to the Harley mufflers...the look is old school until the project is nearly completed (?side-pipes or Oem-location aftermarket mufflers?)
Finalist 2021 C3 of the Year - Modified
Dam, just Dam, talk about exhaust bling, no i am not going to post my exhaust its stock aluminized steel and been on for 15 years now, its a driver.
My crossover is at the back of the trans pan
All of this stuff looks like a diesel exhaust, are we talking 2 1/2 or 3" here.
What kind of temps are you guys getting with a heat gun at the headers/mufflers?
Are those magnaflows loud? I was looking at the exact same set up for my 76.
I need a new exhaust system. I thought about a rear exit system. Mine is lowered, so I decided that I'm going to stick with sidepipes to avoid clearance issues.
side pipes are shown to have a lot less HP...
the only place it really hits is just under the spring/rear-end. so im thinking a 1/2" slit rail mounted on each side of the 2 pips...
#33
With sidepipes I'll probably get STS inserts, try no caps or drilled caps, or 3" inner baffle from ClassicChambered. 1 7/8" primary to 4" and remove the inserts is another option if I need more power. I'll have some fun playing around with it. I'm not sure how much less hp the difference will be than a rear exit. Good idea you have on the skids to protect the pipes where you are scraping.
#34
I have abut 2.5'' ground clearance in the rear, That's why I'm going side exhaust
#36
That would be crank hp..... I have a build thread that will tell you all about it.... Very excited to get her back out on the track
#39
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Paul, I'm a big fan of hooking up a pressure gauge to my exhaust systems to get an idea of the actual capability/restriction of the system. Sounds like you've got a healthy engine for this year's track days. Seems prudent to check if your exhaust system is a match for your engine.
#40
Bee Jay.... What??? ok... im kind of slooooooow,,,,, I don't get it???
69427 at this point... i'm getting so done... i just want to drive her again.... and if a 3" mandrel bend pipe with an X-pipe going through 2, 3" straight through Borla mufflers have back pressure... then so be it.. lol... I give.. p:-)
