82 no fuel to injectors
Old 06-05-2012, 04:47 PM
Rocola
2nd Gear
Rocola's Avatar
Default 82 no fuel to injectors
My 82 stopped getting fuel to injectors. I changed pump and sending unit, filter, and relay switch and that worked for a few minutes, then same problem. I put in a new ECM and chip, car started but quickly lost fuel to one injector and then a moment later the other one stopped, now pump won't come on. Car also has new oil pressure switch, coolant temp switch, distributor, plugs, wires, battery, and alternator. I've also checked all fuses and links. Any ideas? Thanks.
Old 06-05-2012, 05:30 PM
hugie82
hugie82's Avatar
Fuel pressure regulator. Pull the fuel filter line and install a gauge
Old 06-05-2012, 05:39 PM
Rocola
2nd Gear
Rocola's Avatar
Thanks for the advice. I will try that.
Old 06-06-2012, 10:12 PM
terry82
terry82's Avatar
these guys will have the line with the gauge inline ready to bolt on .http://www.crossfireinjection.net/gallery.htm
Old 06-07-2012, 03:32 PM
jdp6000
jdp6000's Avatar
Do you have power to the pump?
Will it run if you pour gas down the TBI's?
Jim
To 82 no fuel to injectors
Quick Reply: 82 no fuel to injectors
