Hard Start and Mis After driving for a while
Old 07-19-2012, 07:01 AM
driddick
driddick's Avatar
Default Hard Start and Mis After driving for a while
Ok.. The car ran perfect until a few months ago
I have a Gen6 454 roller.. approximately 2000 miles..When I start it up to drive it fires and runs fine..
when Its shut it off.. If I try to restart it starts and runs fine..
If it sits for a few minutes maybe 10 or so.. it spits through the carb.. hard to turn over.. eventually if I continually try to crank it it will fire but runs like crap..
after it cools down generally 4 plus hours it runs fine again.. last night it sat for 1.5 hours and ran terrible
It has a MSD 6al, MSD coil, and MSD distributor
I originally thought it was vapor lock but after getting it started I thought driving it for 5 minutes would clear it up but it still misses... the next day.. starts right up
I have not changed the plugs in the 10 months or so I have owned it...
It does have spark during the hard start.. takes a lot of cranking .. spitting through the carb.. even back fires through the pipes when it finally starts and I am driving...
any help is appreciated..
Old 07-19-2012, 09:02 AM
'75
'75's Avatar
Heat soak comes to mind, maybe the gas in the carb boiling and flooding after shut down. But I would think that would clear up and run ok shortly after it starts.
Old 08-07-2012, 03:11 AM
golden50
Cruising
golden50's Avatar
vacume issues do it to my 80 hard starting the more you drive it the worse it gets idiling and eventually driving. look for a vacume leak or a loose plug wire
To Hard Start and Mis After driving for a while
Quick Reply: Hard Start and Mis After driving for a while
