Ground issues?
Old 11-17-2012, 01:14 PM
crazyeight
crazyeight's Avatar
Default Ground issues?
I was having problems starting my 75 and found if I moved the negative battery cable around the car would start. So I trimmed the end of the cable, reset the clamp/collar, then cleaned up the connection to the frame (twice). Now the car won't start. Battery is good, everything turns on but starter doesn't make a noise. Any ideas?
Old 11-17-2012, 02:12 PM
scottw
scottw's Avatar
Are you getting power to your starter? The ground may be rusty and needs to be cleaned up a little. Check tomake sure you are getting power first and then look at the grounds.
Old 11-17-2012, 02:30 PM
crazyeight
crazyeight's Avatar
I am getting power to the starter, tested on the starter ground post. Should I still clean up the starter ground?
Old 11-17-2012, 08:02 PM
billcarson
billcarson's Avatar
try cleaning up the very hard to see, let alone clean,engine ground.
Old 11-17-2012, 08:18 PM
Ironcross
Ironcross's Avatar
check the one {negative} from the battery to the frame area under the drivers side
Old 11-17-2012, 08:39 PM
Doug1
Doug1's Avatar
you can have "power" but not have necessary amps to turn starter with dirty ground
Old 11-17-2012, 09:44 PM
7t9l82
7t9l82's Avatar
the ground cable from the battery to chassis is notorious for trouble. some maybe all were made with aluminum cable clad in copper. once the battery side terminal leaks a little the cable is doomed to corrosion. mine wouldn't start the car on cold days started fine on warm days. that cable may appear fine and be garbage
Old 11-17-2012, 09:51 PM
76Vett
76Vett's Avatar
My battery ground to frame cable was bad, my local NAPA made one with the correct ends for less then $20.00. Just an option if ya need it.
Old 11-17-2012, 11:41 PM
bluthundr
bluthundr's Avatar
Use the negative side of a set of jumper cables to go from the battery to a clean spot on the frame - see if it starts.
Old 11-18-2012, 07:46 AM
bigvette1
bigvette1's Avatar
Maybe I went for an overkill but after I made a new battery to frame ground, a new frame to engine on the starter side and added a frame to engine on the drivers side, the starter spins better than before. I used welding ground cable and soldered brass lugs and used shrink tubing on the connectors, the parasitic battery drain we get when sitting is almost eliminated. With glass cars getting solid grounds are extremely important.
Your not starting could be grounds or it could be the positive cable from the battery to the starter has problems. Take a digitial volt meter and measure battery voltage. Now do the same at the starter referening the + cable and the frame - and the drop should be almost 0. Corrosion, bad crimps etc are usually the problem -- unless you broke a wire on the starter like the "S" terminal. That's if you were messing in that area.
Old 11-18-2012, 08:55 AM
crazyeight
crazyeight's Avatar
Thanks for input. The battery ground is clean, the starter to frame ground is clean and I'm getting good power to the starter using the frame as a ground and using the starter ground post. I also connected the battery to the frame with jumper cables and have the same problem - plenty of juice but nothing from the starter. I'm going to pull the starter and have it bench tested.
Old 11-18-2012, 09:03 AM
gcusmano74
gcusmano74's Avatar
Yes. I had a hot restart problem that went away after I fixed up the battery to frame ground.
Old 11-18-2012, 01:47 PM
bigvette1
bigvette1's Avatar
Probably not a bad idea as if you have a good battery, good cables and are getting a "S" signal at the started, then the starter is more than suspect.
Old 11-19-2012, 09:15 PM
Dino_'72
Dino_'72's Avatar
Agree with Bigvette. Do you have a remote bump starter. If I remember one wire to purple on solenoid, the other to positive on starter. Touching wires or squeezing remote bump starter tool should bump starter. Other thing maybe neutral safety switch. Likely the starter though.
To Ground issues?
Quick Reply: Ground issues?
