Dakota Digital Dash
They are coming out with the later C3 VHX series soon.
http://www.dakotadigital.com/index.c...rod/prd879.htm
It should not be too difficult of an install. Check with a local corvette club if you don't want to take on the install.
Custom Image Corvettes (Josh) is selling the new VHX series... Try contacting Josh and I'm pretty sure he'll be able to get the digital gauges if offered by DD...
https://www.facebook.com/pages/CUSTO...S/272315759556
Rogman
Rogman
I plan on installing this in my 80
http://www.dakotadigital.com/index.c...rod/prd189.htm
$1200
I am also going to explore modifying the center console to house a tablet
Still a ways off but its good to have a plan.
$1200
$1200
$1200
Those VHX systems are way easier to wire compared to using individual gauges to make a custom cluster. I've been looking at a VHX system to put in my 65 Impala and I can tell just looking through the info that it's be WAY easier to wire than individual gauges by the time I try to also put new indicator lights into the dash as well. For example, individual gauges require terminating 6 light wires and 6 ground wires just to get them to light up. The DD unit you just screw a dash light wire into the terminal block.
Most of the wires should just come from the wiring harness that goes to the original dash cluster. Then, add the sensors which run directly and the few extra wires you may need.
$1200
$1200
Looking good. I got the VHX system installed in the Impala. I'm really liking these new analog gauge systems Dakota Digital is building. The control module wires the same except it uses a CAT5 cable to connect the cluster.
I'm running the speedo and tach from the PCM in the car so I jacked it up and ran the speedo calibration counter up to 4000 counts to match the gauges to the internal PCM speed. I checked with a GPS and the speed was high by barely 1kph so close enough for me. In the future if I change tires or anything else I'll just update the PCM programming and the trans shifting and speedo will both be corrected.
