Brake system?????
Old 04-14-2013, 09:05 AM
mk's78
mk's78's Avatar
Default Brake system?????
Hello Forum Folks....
Gotta quickie......Are there any known adjustment or tweaking procedures for a 78 coupe "proportioning valve"????
As always..thanks in advance for your help........
mk's78
Mike
Old 04-14-2013, 09:58 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Mike,
I think the term 'proportioning' is a bit of a mis-name.
It's really just a 'distribution' block. It has no means of adjustment.
Regards,
Alan
Old 04-14-2013, 10:41 AM
Mike Ward
Mike Ward's Avatar
Alan is correct that the earlier C3 valves had no actual proportioning function as they did not require it, but later cars like the OP's did. In any case, the valve is not adjustable nor should there be a need to do so.
To Brake system?????
Quick Reply: Brake system?????
