Car wont start, need help with wiring.....
Hi, I just reinstalled the dash in my 70 coupe. Problem is that the engine wont turn over on the starter. I have power to the coil but nothing to the starter solenoid from the key switch. I have a 70 wiring diagram and the AIM but this car has been fitted with a 77 tilt tele steering column which is confusing me with its connections. Has anyone got a clear wiring diagram for a 77 that would help?
Received 1,254 Likes
You have checked the 4 battery connections and the are good, right?
Have you checked the neutral safety switch (clutch switch).?
77 schematic:
http://www.vetteprojects.com/bmv/mis...tte%201977.pdf
77 schematic:
77 schematic:
77 schematic:
Thanks for the wiring diagram, I will start working my way through this with the 70 diagram as well.
I dont know what all you dissambled to remove the dash but the harness that goes through the steering column could be faulty. happened to me. wiggle the wires and see.
