O2 sensor and data logger
Hi guys, I would like to install two permanent O2 sensors (one for each side) and connect them to a data logger that I can use for logging info and then process with the PC. I would like to keep everything clean, no gauges at all, just a cable that I can hide from the inside and use to connect the laptop.
Do you have any suggestions? brand? models?
thanks
PS: it would be cool if the logger can be connected with my smartphone wireless...
thanks
run this in C4 tech section and also their tuner section, not sure bout the smart phone, but everything else has been covered. thats pretty much how they do it. hope this helps
thanks
thanks
The following system works wirelessly with the iPhone or iPod touch and therefore should work with other smartphones as well.
http://www.aemelectronics.com/wideba...gt-monitor-34/
Unfortunately it only has one O2 sensor but it can monitor two EGT sensors and can interface with dataloggers and engine management systems.
Hope this helps.
thanks
thanks
http://www.zeitronix.com/
Hi Iron_dog,
Just noticed this system from Innovate Motorsports as well. Not sure which of the three systems might work best for you.
I haven't found a wireless system that can support dual O2 sensors but this still might be a contender.
http://www.ot-2.com/OT-2-Bundle.html
That's right guys, I still haven't found a dual wireless system... I've also seen this one:
http://www.summitracing.com/parts/fst-170402
... with the RPM module I need:
http://www.summitracing.com/parts/fst-170536
Quite expensive but complete, with data logger and real time display. I only miss the wireless connection... doe anybody has this system? how it works? thanks
