What is this part?
Old Aug 27, 2013 | 12:17 AM
mac79vette's Avatar
mac79vette
Default What is this part?
So what is this part(the broken door) that is behind the A/C box. I do not see it in any of the parts catalogs. Any idea where to get this?
Old Aug 27, 2013 | 01:15 AM
wombvette's Avatar
wombvette
It closes to cut off the fresh air when you turn to Max or recirculate.
Don't know if it is listed in parts catalogs.
Old Aug 27, 2013 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
As long as it closes the opening in the cowl, you're okay. Might be a little easier to see looking through the end of the wiper trough.
Old Aug 27, 2013 | 11:51 AM
jcloving's Avatar
jcloving
Willcox sells them new. It is the plenum door that closes to recirculate air during MAX A/C.
Looks like a badger got a hold of it and took a bite.
Old Aug 27, 2013 | 01:14 PM
wombvette's Avatar
wombvette
They tend to get chewed up because of the sloppy bonding material in there. I have actually seen them stuck by the added sealer, or worn off from rubbing on the walls. Lots of times the rubber hose is pinched behind the bracket and the thing has not worked since new. A common source of cooling problems.
Old Aug 29, 2013 | 03:10 AM
mac79vette's Avatar
mac79vette
Thank you all for the info.
To What is this part?
