defference between 350/300 and 350/350
higher compression, different cam, forged versus cast internals, different heads, etc. Go to this link, select corvette and than select 1969, it will give you all the details
http://www.gmheritagecenter.com/gm-h...tion-kits.html
Received 2,878 Likes
Hi 55,
I think part of the L-46 option was a bigger smile for the owner to wear too. I believe it was one of the items in the owner's packet.
Regards,
Alan
Regards,
Alan
Same casting number cylinder heads, L46 had 2.02 intake valve and base motor had 1.94. L46 had open element air filter for 1970. Not sure of 1969.
Bob
Bob
This is over simplifying things, but basically, the L46 used the same bottom end as the LT-1, with a hydraulic camshaft. 4-bolt mains, forged crank, pink rods, forged pistons at 11:1 compression ratio, etc. The 300 HP version was the same engine you could get in a station wagon, 2-bolt mains, cast crank and pistons, lower compression, smaller cam. I believe the L46 was the only optional small block you could order in 1969, standard engine being the 300 HP station wagon engine.
Scott
Scott
OOh the 300hp is only a 2 bolt main and came in a station wagon. not liking that much
Received 1,246 Likes
WOW! I must be old I remember having a station wagon.
Scott
Scott
Scott
I'll go out on a limb and say all the early C3s had four bolt mains.
Pete
'70 300 hp was four bolt main as well
'69 Chevelle 4 door 350/300 hp was four bolt also, pretty sure they were all four bolt, 10.25 compression cast pistons. Corvettes and trucks may very well have all been steel/forged cranks, may have all been steel cranks in 300hp and up . (my memory is getting too old to remember).
'70 and earlier they were worried about having warranty issues so they used alittle more beef in the lower-end. With the lower compression of '71 & on they didn't have those concerns and the engineers were now busy with
emissions.
emissions.
It was the base engine in the 'vette, and probably an extra cost option on the station wagon, if that makes you feel any better. Probably a different RPO, too, but essentially the same engine. But hey, it's a small block chevy. Souping up a SBC is as easy as falling in love.
Scott
Scott
The 350/300 is a good starting point
My wife hates station wagons because she had to ride around in one as a teenager...yet she drives an SUV which in my mind is nothing but a station wagon with big wheels....
Also, I thought that Corvettes always came with four bolt mains - no?
Received 1,469 Likes
Cruise-In II Veteran
