Will LOW CC chamber heads help my low compression BB?
Ive got a 72 big block with stock pistons and heads. (Mild cam, upgraded intake, carb and exhaust) I know the low, smog controlled compression ratio is what KILLS the performance on this engine. I want to add new heads but I DONT want to mess with pistons. I know Edelbrock makes a 94CC head. Will the lower chamber size increase compression enough to warrant to 2K price tag? Are there any other options?
Haven't seen 94cc Edelbrocks. I have the 100cc "High Compression" oval ports.
Have you tried a compression ratio calculator? Enter all your info and it figures out the static compression ratio. Then re-do it with the new info from the heads and compare the 2. Then do a search on the effect of a compression ratio change between 8.5 and 9.5 to get an idea. You're not going to see a 10% change. If you did get the heads, I would suggest that you contact Chris Straub for a cam recommendation. He will get the most out of the potential that you have.
I have the same Edelbrock heads and that's the correct chamber size. Do you have the specifics on your pistons? If the engine has been gone through since it left the factory you'll want to know exactly what you have. That could be important info since you'll lose some valve to piston clearance with smaller chambers. I'm not trying to discourage you because the Edel. heads will pick up power nicely due to superior flow anyway, and crisper throttle response due to increased compression would just be a bonus. Do you know the specs on your cam?
100cc Edelbrock heads will help, but not be enough. I have a '71 LS-5 with those Edelbrock heads. With the block decked to 0.005" and 10cc dome pistons I'm at 10.15:1. Factory pistons were flattops.
When I had my engine done it also turned out that a PO had installed some truck pistons with a different pin height that dropped the pistons down about 0.040". And to top it off, the decks were crooked from the factory. One end was 0.020" higher than the other end. The worst piston was about 0.080" down!
If the PTV clearance is less than adequate you could have your pistons flycut while they are still in the motor so you wont have to mess with it hopefully.
May be worth it to go to a good performance shop that has done head and cam swaps etc.
I'll bet the tops of those pistons have plenty of meat on them just ready to be cut away so those valves will fit.
So whats the general consensus? Will the 2 grand price tag net me an extra 35-45 HP like a good set of heads usually does or are my stock pistons just going to keep holding me back? I honestly hoped that the Edelbrock heads would be a bolt on operation.....
Oh, easily more than 45 hp! More like 60-70 hp with the heads alone. Your low compression is still holding you back, but the Edelbrocks flow so much better than the stockers.
(are there ANY other small CC heads other than Edelbrock? 2 grand is just too much right now....)
If all you are concerned about it chamber size why not just have YOUR heads milled down???
Nothing that will flow well. You can mill down factory heads, but it's not going to make much of a difference as they don't flow. By the time you fix up factory heads (new valves, guides, milling, porting) you've probably spent close to the same money.
