Forged vs Cast Pistons???
Old 10-08-2013, 07:00 AM
Vet76te
Vet76te's Avatar
Default Forged vs Cast Pistons???
This is a question for all you gear / motor heads.
I know that all the old high performance engines came with Forged pistons and rods, (L88, LT1, L82, etc).
All base engines came with Cast pistons.
What was the purpose and reason for the Forged over Cast pistons? Was it simply for endurance, strength, weigth or performance?
Old 10-08-2013, 07:24 AM
bashcraft
bashcraft's Avatar
Originally Posted by Vet76te
What was the purpose and reason for the Forged over Cast pistons? Was it simply for endurance, strength?
Yes.
Old 10-08-2013, 07:27 AM
CaseyJones
CaseyJones's Avatar
St. Jude Donor '15-'16
All of the above.
Old 10-08-2013, 08:19 AM
zwede
zwede's Avatar
Back then forged pistons had some drawbacks (besides cost):
Since they were loose when cold, there was often noise before the engine warmed up. Oil consumption also tended to be higher than cast pistons.
Today there are "street series" forged pistons that have cured most of the issues. But my 454 does clatter a bit above 2500 rpm before it warms up.
Old 10-08-2013, 09:04 AM
hugie82
hugie82's Avatar
Forged can take the abuse of high compression, high rpm, high heat and a shot of NOS. the new Hypertec pistons that pretty much took the place of cast are great for a good street car but if you beat the crap out of your engine forged it the way to go
Old 10-08-2013, 10:36 AM
Indiancreek
Support Corvetteforum!
Indiancreek's Avatar
Forged are more durable, however, many cast piston engines have been raced. Lots of SS396s during the muscle car years ran cast pistons. The only reason I'd use cast pistons in an engine would be a money issue. If I could afford forged I'd buy them. Honing a block for a forged piston is a little different than for a cast piston.
Old 10-08-2013, 11:08 AM
bashcraft
bashcraft's Avatar
What's different?
Old 10-08-2013, 12:30 PM
donyue
donyue's Avatar
I believe that the forged pistons were used in engines that would potentially see more abuse than a regular street engine.
Most if not all race/high performance engine builds use forged pistons.
The reasons you have mentioned provide a good summary, however if you chat with an engine builder I'm sure they would have additional reasons to use forged vs cast pistons that the average person might not take into account.
JMHO.
Old 10-08-2013, 03:13 PM
Indiancreek
If the owner is running forged and going to run it harder than normal I'll put two or three extra tenths in each hole. Some guys like an extra five tenths per hole.
The derby guys want even more than that. As they will be run very hot.
Old 10-09-2013, 06:57 PM
Little Mouse
Little Mouse's Avatar
On the 60s/70s OE engines forged pistons added strength and endurance but cast pistons were lighter. Today with different alloys of aluminum in forged pistons you can run tighter clearance and the pistons and pins are lighter. No reason to run a cast or hyper piston unless its the cost driving the decision. Today as in the past the OE manufactures build millions of engines so the cheaper cost of hyper pistons saves them a lot of money on millions of engines built over the yrs.
Old 10-09-2013, 07:11 PM
loup68
loup68's Avatar
I have a ZZ4, Is it true that the 5800 RPM red line is because of the hypertec pistons, that they can not rev higher? Lou.
Old 10-09-2013, 07:49 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
FWIW 4032 is the low expansion forged alloy piston. I didn't even give anything else consideration for my 427 high-perf redux.
Old 10-09-2013, 08:11 PM
badrad
badrad's Avatar
Not really, many of GM performance engines today have hyper pistons but don't let it detonate. Hyper pistons tend to shatter into dust when that happens, tune needs to be perfect for the most part so modern fuel injection goes along way towards that.
Old 10-10-2013, 06:44 AM
bashcraft
bashcraft's Avatar
Engine red lines are usually determined by the limits of the valve train.
Old 10-10-2013, 08:00 AM
76Rat
76Rat's Avatar
and crankshaft and connecting rods, but mostly due to the hydraulic lifters.
To Forged vs Cast Pistons???
Quick Reply: Forged vs Cast Pistons???
