77 C3 Tranny mount & driveshaft u joints
I have to replace both U joints on my center driveshaft and the tranny mount. I can either jack the car from the side with jack stands or use a set of ramps on the front or rear wheels. Which method would best serve my needs? I have a real bad back and someone's input will save me a lot of pain.
Jack
77 L-82
63 SWC
Jack
77 L-82
63 SWC
If you are going to change the u-joints in the half shafts its a lot easier if you can rotate the wheels to get to the bolts that are on top rotating them to the bottom.
Jack
Thank you, but i didn't say rear halves. I need to replace the front and rear U joints on the driveshaft that goes from the tranny to the rear. The tranny is automatic. I know that if I pull out the driveshaft, the yolk in the tranny will start pouring out fluid from the tranny. Can I do this job on the car without pulling the yolk?
Jack
Jack
Jack
Jack
Buy two more jack stands and use all 4, one under each recommended lifting point . it's the easiest way to work on these cars.
