Share Your C3 Upgraded Wheel/Tire Combo's
Old 09-22-2015, 10:35 AM
  #421
BigBlock77
BigBlock77's Avatar
Originally Posted by Robby04
Hey great rides guys.
Does anybody know if c5 wheels fit our c3's?
Several members have fit C5 wheels to the C3. It takes adapter/spacers and the amount of offset depends on the wheel you choose and the back spacing. I'm leaning towards the C5 Z06 wheel when I get mine back on the road. I prefer the looks of the original slotted wheels on my car, but I have a hard time paying for the crap 15" tires that are available when there's a lot bigger selection on more modern wheels. Look back through the thread and you'll see several with C5 wheels.
Old 09-22-2015, 11:12 AM
  #422
bluegtp
bluegtp's Avatar
Yes they do. ..... they usually require adapters and some require modifications.
Old 09-22-2015, 11:24 AM
  #423
Robby04
Robby04's Avatar
Thanks for the reply. I'm restoring a c3 74 stingray vert 454 4 speed. My dad is original owner.
I have a c5z. I found some great hres in the c5 section. I'd love to put them on the c3. But adapters don't sound to good to me. I will just wait till the correct size comes up. Thanks for the info
Old 09-22-2015, 11:26 AM
  #424
Robby04
Robby04's Avatar
Thanks for the reply. I'm going to simply pass on the deal I found. I wish for them to bolt up perfectly without modification. Thanks
Old 09-22-2015, 07:28 PM
  #425
81corvettevortec
81corvettevortec's Avatar
Definitely need spacers. 2.5inch and 3inch is what I used. Have been running them for 11 years without a single issue. Granted I wouldn't be putting on a set of slicks and hitting the track with them either.
Old 09-22-2015, 08:42 PM
  #426
Robby04
Robby04's Avatar
Thanks for the specifics and pics. I rather not run the spacers. So I'll wait on the wheels. I just thought I had found d a great deal. I could see putting my stock c5's on w spacers. But not buying fancy hre's. Thanks for the info.
Old 09-30-2015, 10:32 AM
  #427
newbie2vette
newbie2vette's Avatar
These are the new TQ Thrust with the new chrome 15X8X3.75
Hellah fresh (02-05-2024)
Old 09-30-2015, 10:49 AM
  #428
sfsvettes
BubbaHut
Support Corvetteforum!
sfsvettes's Avatar
Default spacers
Yes , they will be spacers are required to get proper back spacing.
See the attached photo of my buddy Chris G 's car out west
Old 10-03-2015, 12:35 PM
  #429
FLYNAVY30
FLYNAVY30's Avatar
Received 2,366 Likes on 1,034 Posts
Was just looking at those but in the gray centers....what size tires did you go with?
Thanks!
Old 10-09-2015, 06:00 PM
  #430
Aflac
Aflac's Avatar
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I tried putting a set of 17" off of a '91 on mine. The rears fit with the usual parking brake bracket relocation, but the fronts just didn't work. it would hit with any steering input beyond about a 1/2".
I was using 2.5" spacers all the way around and 255 50 17 (I think; it was last year when I tried). I even took it to the best alignment shop in the area that is really good with our cars and he looked at all of the dimensions and everything looked even from side to side. Any ideas, folks?
Old 10-09-2015, 06:29 PM
  #431
C3s4me
C3s4me's Avatar
Default Work in progress... 295/50/15 rear
Here is a few photos of my old school 69...435
Front 15x8 4 inch back spacing 235/60/15
Rear 15X8.5 3.5 inch Back spacing 295/50/15
No mods done to anything. Stock T-arms and brake bracket still in place.
Note: it does have F-41 suspension from factory....
I now have proper interior that I still need to install with paint job... Give me a few months...
My add some tred wear letters to tires...
The following 2 users liked this post by C3s4me:
Hood Black (03-22-2024), Old Man Wolf (06-12-2019)
Old 10-14-2015, 11:08 AM
  #432
81corvettevortec
You'll have to compare the offset of the wheels you tried with that of a regular C5 sized wheel (thats what I used, non-Z06 size but same style wheel). The factory C5 wheels definitely fit with the spacers I mentioned though. I even had a shop install the rears on the front by accident and didn't have any rubbing whatsoever. Also consider if you're lowered, my car is not.
Old 10-20-2015, 11:05 AM
  #433
Strokemyaxe
Strokemyaxe's Avatar
She's a beauty!
C3s4me (10-24-2015)
Old 10-20-2015, 01:25 PM
  #434
commander_47
commander_47's Avatar
C5 wheels most definitely fit after moving the emergency brake clip. You need to use the big adapters and Loctite. 100lbs torque on the adapters and 80 lbs on the wheels.
C5 has 17 inch front and 18 inch rear. You can use 245/45/17 up front to give the car a little rake and improve handling. If you want to fill the wheel well, use 245/55/17.
Rears are 275/40/18.
Old 10-20-2015, 07:43 PM
  #435
newbie2vette
Thanks!
Sorry for the delayed reply. I used 255/60R/15, they rub a little during a sharp turn. It sure gives the car a nice stand.
Old 10-21-2015, 08:02 PM
  #436
C3s4me
C3s4me's Avatar
Default Thanks
Originally Posted by Strokemyaxe
She's a beauty!
Thank you...
Old 10-22-2015, 09:14 PM
  #437
Al Kay
Al Kay's Avatar
Eventually went with 17x8 front 245/45 and 4 1/2 bs, and 17x9 rear 275/45 5" bs. Very happy
To Share Your C3 Upgraded Wheel/Tire Combo's
Old 10-23-2015, 01:21 PM
  #438
Calo69
Calo69's Avatar
St. Jude Donor '15-'16, '18
Thank you...
Lettering looks better imo. Good luck
C3s4me (10-24-2015)
Old 10-24-2015, 09:11 PM
  #439
mlk396
1st Gear
mlk396's Avatar
Default wheels and Tires
I'm putting on 16x8 aftermarket wheels on my 69 Vette . I'm concerned about what size tire to use because clearance and etc..
I've been looking at 225/60R16 .
Help...
Old 10-24-2015, 09:25 PM
  #440
Plasticfreak
Plasticfreak's Avatar
Fkn hot! Love that vert!
My plastic in prime..............
C3s4me (02-05-2016)
Quick Reply: Share Your C3 Upgraded Wheel/Tire Combo's
