seized fill plug on Muncie 4 Speed Transmission
I have a 71 Vette with a Muncie 4 speed transmission. I would like to replace the gear oil in the transmission but the fill plug appears to be seized. Any recommendations on how to get it out? Can I use heat under the car? Should I just drop the car off at Aamco Transmission Repair?
Thanks guys!
Thanks guys!
The Fill Plug should be Steel and the case Aluminum so they should not seize.
Ed
Thanks guys!
Thanks guys!
Try a can of the CRC Freeze Spray and spray the heck out of it, for at least a solid thirty seconds to a minute (because of the size of the plug). We use it in the shop all the time.
CRC Freeze Off Super Penetrant - YouTube
Question: The drain bolt/plug on my Muncie 4 speed transmission appears to have no head. Is this broken or is that how it comes from the factory? Here is a pic of a transmission case I found on E-bay that looks exactly how the case on my car looks.
http://www.ebay.com/itm/1968-Chevy-C...97b43f&vxp=mtr
Starting in 1970, all Muncie 4 speeds had both the fill AND drain plugs, so if your transmission doesn't have the drain (only the fill), it's not the original main case. Before then, only the M22 had both the fill and drain plugs and the M20 and M21 drain plug boss wasn't drilled.
Ed
Ed
It takes a special 8 point socket to remove the plug. Using an open end wrench is a big mistake...or can be quite quickly.
DUB
DUB
propane torch , heat the plug , melt candle wax onto the threads, it worked for me. i agree 8 point socket.
I work in the marine industry and we get parts that have been out in saltwater for 30 years or more we need to get apart. Nothing beats Heat, if You can heat a bolt till its red and let it cool back down it will just about fall out. Two reasons the heating breaks loose the rust, and when the bolt cools down it will be smaller in diameter than it was new.
Maybe a Trans case in the Car isn't the best place to be doing this, but the Freeze idea is doing the same thing, its just a lot more convenient in this situation.
Thanks for the advice. I wound up taking it to AAMCO. As it turned out the front and rear seals where bad as well as the side cover gaskets, all old and perished. They did a good job replacing all that lot. Car runs great now. Just gotta replace the distributor. ( posting new question related to distributor subject).
