Front end alignment and conversion to Power Steering
OK so I converted my manual steering 1972 Stingray to a power Steering Setup, I also added a hydroboost power Brake system to the Base Model Vette. During the conversion I swapped out all the old front end suspension for new stuff..... Stuff includes, Ball joints... upper and lower , tie rod ends and rods, Idler arm , Pitman arm for Power Steering, upper and lower A arm bushings. the Power Steering kit came with all the control valves, actuators, linkage and pulley.
the only things that I did not change on the front were the shocks, springs and sway bar bushings
So I got it all together the systems work fine and of course the last step in getting it all back together was the alignment. so the computer alignment went well. the car drives nice and straight.
the issue I have is when I accelerate hard the front comes up and I get tire squeal and the front gets loose.
now some additional information the rear end has all new trailing arms spindle bearings and bushings thru out. the rear end seems tight.
although I do not have a rear sway bar. could this be causing the issue with the from coming up under acceleration
Has anyone had similar issues with the front end.
Thoughts and comments welcome
Assuming your steering box is tight and that you're not on the verge of a wheelie, it sounds like you might possibly have excessive front tire scrub during suspension travel into droop, causing beyond normal loss of traction when the front end unloads (BTDT).
It's usually best to work on the end of the car with the apparent problem first. With that in mind, what are your static alignment specs, and current springs, bar and shocks?
Had that situation on one that had some front end frame damage. It had been pulled and left with excessive spread on the front cross member. It had a serious stack of shims on both sides. We worked that back a little and realigned. But, another thing found while working it out was that the upper a arm bumpers were not installed which let it lift more than it should.
Noticed the skunkworks reference LM ??
The springs are oem orignal the shocks seem firm with no excessive float the front sway bar is also oem stock as far as I can tell when I had the front end out I measured the springs for height they were within 1/8 in of each other don't recall overall length I will load the alignment specs when I get back home but Goodyear computer specs for 72 vet is what was used
As for LM, no, I'm just an avid enthusiast of the black arts. If interested, you're welcome to read more about that here starting at the OP...
