C3 Gauge problems
C3 Gauge problems
recently installed new dash,driver and passenger panels and new center console w new gauges. Voltage,oil pressure, clock, seem to work ok. Water Temp always reads @230 and goes down to 220 after driving a while. Ran out of gas today new gauge showed 1/4 tank also installed a new low fuel sensor which never came on. A new circuit board was also installed. Any ideas or help would be appreciated.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
you installed a new gauge for the fuel gauge? If you did, did you re-use the resistor. If you did remove it and the gauge should read correctly. The new gauges have the resistor built into the pod so you use the spacer that came with the gauge and no resistor.
If you have the resistor in place, you're now running 180 ohms resistance..
Willcox
Willcox
Why would you replace gauges that worked fine??? Any changes you make to something requiring 'calibration' is asking for problems.
Sorry... I'm just against the process of swapping out 'stuff' just to make it look better...
Also.. Whenever one makes changes to gauges, it is best to check calibration and/or operation before complete reassembly. Differences in calibration between sensors and gauges is a VERY common issue.
Gauges
[QUOTE=7T1vette;1587769747]Why would you replace gauges that worked fine??? Any changes you make to something requiring 'calibration' is asking for problems.
Also.. Whenever one makes changes to gauges, it is best to check calibration and/or operation before complete reassembly. Differences in calibration between sensors and gauges is a VERY common issue.[/QUOTE
Thanks for the reply but were did you get the idea that the old gauges were working fine... just FYI the old gauges were not working..... I too do not enjoy spending money uselessly .............
My question to you is where did you buy the new gauge cluster? Is it a restored factory cluster or a reproduction. What was the original problem with the gauge(s) that did not work and how is it now compared to the originals.
What did you fuel gauge do before you replaced the cluster. The resistors on the gauge typically range between 97-103 OHMs and depending on the manufacture may or may not be required. I would make sure that is not your case.
Have you done a OHM test on the sending unit? It has a 0 (at empty) - 90 OHM (full) range. They are easy to test if you have a DVOM.
I would not be surprised to find out the fuel gauge needle was installed incorrectly. It is a common problem on stock gauge restorations.
I can help you diagnose if you are willing to do some procedures.
Take care,
Tom
Take care,
Tom
Thank you for your reply. Yes I did install a new fuel gauge and a new low fuel warning module. I did not use the old resistor. The fuel gauge at 1st showed 3/4 full and I ran out of fuel at 1/4 tank. Im also trying to find out were the water temperature sending unit is on the 77 350 block
Take care,
Tom
Take care,
Tom
Since you bought these and they were Delco parts, they should use a resistor to work correctly. Did the new gauge come with a new resistor or instructions that advise against using one?
When the gauge does not respond at all, it usually means it has lost 12V to the gauge or the gauge is just bad. Now that you have a new gauge, it sounds like you have another issue. What happens if you remove the tan wire from the sending unit or un hook the ground from the sending unit? The gauge should read at 3 o clock.
Is the fuel gauge sending unit easily accessible on a 77? I am not that familiar with the year.
Former Vendor
The gauges are not made by Delco... they are imported from China in a Delco box. Bogus b/s if you ask me... but I'm not the one making them. I carry them as do other vendors... and they work nicely when installed. But they also come with a tiny print instruction sheet and if you don't pay attention to it.. we'll they won't work if you use the original resistor in line your new gauge will not work properly.
IMHO,
Willcox
IMHO,
Willcox
IMHO,
Willcox
IMHO,
Willcox
It seems to be a common theme for these new aftermarket gauges that are eliminating the resistors and throwing a lot of people a curve ball.
Thank you for the knowledge.
Tom
IMHO,
Willcox
IMHO,
Willcox
Former Vendor
Good information Willcox. I have not had the pleasure of working with these new Delco gauges. I prefer to find good used originals and bench test them before they are installed.
Tom
Tom
They are china made.. how they get way with this I have no idea... It's sad that the boxes say Delco...
I've done extensive research on all the gauges over the years and the end result is the video's, tech pictures and tech video's on our site to help you guys..
But one of the most common mistakes made with the china gauges is that the resistor is used.. when this happens you are doubling the resistance on the gauge and it will always cause a problem.
If I was the OP.. I'd pull the center bezel.. and double check the resistors.. if they are there, remove them.. If they are not then you contact me at the support address and make sure you tell me what the needle is doing because the needle will always tell the tale..
Willcox
