L88 Air Cleaner Drop-Base work with Aftermarket Fuel Injection?
Has anyone added an aftermarket throttle-body-type fuel injection set-up and used a standard L88/LS6/L36 factory 2" drop base air cleaner assembly with it? I'm thinking of adding injection to my 540. I currently have a Victor Jr. single plane manifold, an L88 non-fresh-air-chamber hood and the factory drop base open air filter assembly.
Also, what was the true installed cost of your fuel injection system and what did you use? How happy are you with it? Any problems. I don't want to substitute carb inconsistencies for EFI issues.
Thanks in advance for any advise and opinions.
I used the L-88 base and made the L-88 air box functional. I'm have the Holley HP EFI and I'm using their single plane intake. I had to mill 1/2" off the top to get it under the hood.
My true cost... well, my motto is to never add up the receipts!
It could be duplicated for less... I also went with a stainless tank with in-tank pump, extra wideband O2 with gauge, etc.
Runs well. Never regretted dumping the carb. I consider them semi-controlled fuel leaks.
CI 5 & 8 Veteran
A while back I decided to upgrade the engine in my 1969 BB corvette convertible. Went with an all aluminum Dart 540 setup. Back in the late 70's we had the original 427 modified for L-88 type performance. (High compression, high rise intake, GM L-88 hood, etc.). Old school horsepower requiring high octane racing or av-gas fuel. Hard to have much fun driving these days with only pump gas readily available.
Anyway, wanting to keep the same look of the car , a major design requirement was to fit and interface with the GM L-88 hood with its airbox un molested. The high horsepower Dart engine had a few constraints as well.
This is what I have ended up with. I will be dropping it in, hopefully, this weekend for initial fit checks
Engine configuration:
540 cubic inch (~10.2 CR)
Dart aluminum short block
Dart Pro1 CNC 355 aluminum heads
SCAT 4.25 forged crank
SRP 10 cc domed pistons
Manley piston rods
Proprietary Mechanical Roller Comp Cam
Super Victor intake drill modified for shorty low impedance injectors
Jones accessory brackets.
FAST low profile 1,375 cfm Throttle Body
I purchased an aftermarket drop base that should fit after some modification for the Low Profile Fast Throttle body linkage. I plan to put a small K&N air filter in place of the old screen guard. Even though the Throttle body has the larger Dominator like intake ports, it will fit up into the hood just like the old L-88 design.
Manley piston rods
Bullshark, I would probably get into trouble with a motor like that!
Manley piston rods
Manley piston rods
