73 Frame Replacement
69-74 frames will work. If you buy a frame from an auto trans car you have the removable trans crossmember that makes mounting the engine/trans easier.
A 74 frame will need the bumper plates cut off. Earlier frames have front frame bumper mounting holes that don't quite match the 73. I put a 73 frame under my 72 and had to fudge around with the bumper support brackets to get them mounted.
You can use a 75-later frame also but you will have to cut the rear section of your frame and graft it onto the later year frame. There are pics in the forums showing how that looks. Fortunately the rear sections of rotted frames are usually in pretty good condition so you could use your frame as a donor.
Rick B.
Rick B.
Call 'Vette Products of Michigan'. They make replacement factory frames. I have had to get several from them over the years.
DUB
DUB
I found a direct replacement - 73 4 speed - and although a bit pricey I think that's the way I'll go.
How's the quality and price? I thought I read somewhere there were some alignment issues? I've seen vendors selling used, reconditioned frames for about $4000.
I have not had a problem with them...and the costs of repairing the factory rusty frame is kinda pointless in most of the cases when the frame needed to be replaced...
AND...I do not like to use used frames...unless they are really in good shale and cheap due to it will go on a frame machine and have it measured out and pulled to get it correct...and if it is bad enough...that can end up costing so close to a new frame with NO RUST...it becomes a 'darned if you do----darned if you don't' scenario.
DUB
A new one was about $5300 delivered to Maine. A good used one 2-3k but ya gotta find it and go get it.
I do not know what you mean about 'alignment issues'...You need to be more specific and not so vague. This response can be given by people who do not know what they are doing....or teh competition trying to give the parts a BAD reputation.
DUB
DUB
