Help turn signal issue
Hello I have just got my corvette back from paint and before I put the rear tail light lens back on I checked lights and turn signals etc... The passenger side rear turn signal is not working. I have changed the light bulb with a known good one still not working. Hazard lights flash only driver side and front lamps. I turn on headlamps and that rear element lights. When I turn on the turn signal the dash indicator lights solid (no flashing) and no light in the back passenger lamp. If I look close at the front lamp it is extremely dim and solid. The sockets are clean with no paint and corrosion. Do the wires run along the side where the door thresholds are. Just trying to see if maybe a wire is pinched. Everything worked fine before the paint job.
Paul
This was posted in General but I guess here might be better.
Paul
Received 2,878 Likes
Hi P.E,
The rear lighting harness runs along the left rocker channel under the carpet and just to the inside of the sill plate.
The sill plate needs to be removed to access the harness.
Back at the lights…are all the grounds connected? I believe there's one at each light. The ground forms a 'string' from light to light.
Regards,
Alan
Regards,
Alan
Hi P.E,
Regards,
Alan
Regards,
Alan
Paul
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I think I would double check the parking lamp connection to the main harness. It's pretty common for the ground to not make contact and then back feed. I feel sure you have a ground issue. You could up-plug the parking lamp and insert a test lamp in it's place. Use the light blue and black wires (lh side) and the dark blue and black (rh side). (the brown wire is the parking lamp)
If that's not the case I'd then pull the lens and bulb out of the tail lamp and with test light, test the brass in the housing is a good ground. If you don't have a good ground on the brass then touch the housing stud.
If you have done the above then the next place I would check would be the turn signal switch connector. Make sure it's plugged in nice and tight.
Willcox
Willcox
Willcox
Willcox
Received 1,246 Likes
Many times the connection where the black wire goes into the brass light socket corrodes and you loose the ground. Here's a way to check.
Connect a wire to a good ground and touch the brass and see if the bulb lights up.
Anyone know where the front to back diconnect connector is located?
My lights are ALL working now thanks to Willcox Corvette's diagram. It ended up being the connector under the dash. I unpluged it to put 12volts on it and I told myself that I needed to check what is not working and what is working first. So I plugged the connector back together and started with the Hazard lights and they worked so with those working the turn signal should too. Sure enough I tried the turn signal and they worked. The painter must have kicked the connector getting in and out of the car. Everyone thanks for all the help.
Former Vendor
Have a happy Thanksgiving.
Willcox
