76 Need Help Unlocking and Opening Door on 76
I can't unlock or open drivers door on my 76.
Last couple times I opened the door the outer door handle felt like it didn't have a spring in it. There was almost no resistance.
Other night I locked the door. Now I can't unlock the door using the key or by turning the **** inside the car. I can only turn the **** or key about 1/8 turn.
I can't open the door using the outer door handle or the inner door handle.
Can I open the door using a screw drver to actuate the latch mechanism if the door is locked? Oreo I have to get the door unlocked first.
Any ideas? Is it possible to get the door panel off with the door shut, without destroying the door panel?
Roger
Roger
https://www.corvetteforum.com/forums...-corvette.html
As long as I can get your window down...I will be in your car in 15 seconds or less.
The PROBLEM you are having is stuck/binding linkages....or broken clips causing the rods from the door handle not to work correctly.
DUB
DUB
Roger
I would put money on the fact that either a clip is broke and the rod is off....or the SPECIAL clip that goes on the rod at the handle is broke and the rod is pinched. Can be a broken handle also...but usually it is the clip(s).
DUB
Just to clarify, even with door locked, I can push down on the plate in the photo (referenced thread) and door will open?
Roger
I got it open by pushing down with a long screwdriver like Dub said.
Turns out the linkage between the outer handle and the door mechanism had partially came unhooked. Put it back, oiled everything and back in business. Thanks for everyone's help.
Roger
Roger
The clip at the handle area.
http://www.parts123.com/parts123/yb....Z5Z5Z50000036b
DUB
