New Grant steering wheel,and no horn!!!!!!!!!!
I just installed a new Grant Steering wheel on my 76 Vette,and need to wire my horn up.The horn has never worked on her due to not having a steering wheel when I bought it.All the wiring has been replaced in my vette,Main dash harness,engine,forward lights,ect.Can anyone tell me what wires I need to use to connect to the 2 male prongs on the back of the Grant horn button?I've looked and looked online for answers,and realized if there was anyone who would know,it would be the guys on here.I thankyou in advance for any help you guys can give.
IIRC, there is only one wire in the column for the horn, the other side of the OE horn switch is grounded through the column.
When I installed my Grant, I had to add a ground wire from the second prong to the adapter. Works perfectly.
Great,But which one of all those wires is the horn wire?
How many loose wires do you have in your column?
I can pull out my wiring diagram and find the color of the OE wire. However, you mentioned that all of your wiring has been replaced, so that info may be irrelevant for you. I would suggest some checking with a multimeter - the connection at the horn is easy to get to, should be able to find the column end pretty quickly.
Nam Labrat
Received 4,178 Likes
Shouldn't the harness wire be constantly hot that plugs into the column harness for the horn?
On my '68 there is a separate 2-prong connector just for the horn (one wire is constant HOT/the other wire is a frame ground)
If you have single wires dangling, Use your multimeter/voltmeter to find the constant HOT wire.
Nam Labrat
OR...........
find the horn fuse in the fuse box/panel........find the "output wire" that the fuse feeds.....connect THAT WIRE to the horn contact at the top of the column where the button snaps on.
There isn't a 12 volt hot lead for the horn in your steering column. What you do have is a ground going through the column. I'd verify the problem is actually IN the column before digging in. Find the ground lead leading from the column and simply give it a good ground. If the horn blows, the issue IS in the column. If it doesn't blow, it isn't in the column
