71 Corvette fan question
So, I installed an aluminum radiator in my 71. I also replaced the fan shroud (original was cracked and was being held back with zip ties). The problem now is the clutch fan will not fit with the new shroud...what gives? The shroud is identical to the factory...any help would be appreciated. What size fan should be in the 71?
Thanks, Bill
Thanks, Bill
Received 2,878 Likes
Hi Bill,
I believe the size of the fan depends on whether the car is a sb or bb, and also whether it has a/c or not. Whether a car has a/c or not influences the number of blades too. 5 blades without a/c, 7 blades with a/c.
The fan on a sb without a/c is 18" in diameter.
Regards,
Alan
Regards,
Alan
Hi Bill,
I'll ask the same questions as Mike did.
Regards,
Alan
Regards,
Alan
I read your post as the fan is to high. Agree with Mike though about motor mounts. I just replaced the swollen, separated mounts on the 72 and could see the clearance difference between the top of the fan and the shroud.
