Lift an engine from the intake manifold or the heads?
It is 125 lbs per bolt pulling straight out, not at an angle. you won't pull the heads of them off or pull the threads as long as you have full thread engagement.
With the head bolts you're dealing with the shear strength of the bolt and can use a grade 8 if you choose. With the intake you're dealing with the tread strength at what ever condition they have to be in at the time.
It has nothing to do with believing anyone.
As an ME, I know on paper the threads should hold-
In practice, do I want to bet my life on 5/16" hardware/threads when 3/8" is readily available? For me personally, no-
I've seen too many manifolds with buggered up carb pad threads and don't even get me started on the QC of aftermarket parts.
But don't let me stop those of you that are more confident than I.
I bought a load leveler from harbor freight that came with brackets. I hooked to 3 intake manifold bolts (used the stock bolts) and on hole in the head that my alternator bolts too. Everything went well. Im sure lifting straight up from the carb pad is fine, but I knew Id be jerking, pulling, and cursing this motor out. I just went with the theory bigger is better. (the bolts holding the lift mounts)
In Nascar I put Hundreds of Engines in and out W/ Headers, Bellhousings and Tranny with Carb plate only, I put my engine in and out of my Corvette with a Carb Plate, But the Big Block in the Nova SS got 4 corner chains off the heads
jim-81 (09-05-2018)
Location: Las Vegas - Just stop perpetuating myths please.
Ok, now that its a done deal i dont have to worry the consequences but i never used more than 2 bolts - on the intake to head bolts - whatever size they are. If u look at most OEM crate engines they have a loop plate usually at 1 end, sometimes both ends of engine and the bolts that hold that plate are tiny. I want to say 1/4-20 but too lazy to dig up my used ones up right now to measure.
For maneuvering the engine i liked and bought this TPIS "Happy Hooker" lift plate: http://www.tpis.com/parts/view/67. But havent got to test it yet. It will pick up from carb mount or the GEN II LT1 intake.
An ME who doesn't trust his own calculations isn't much of an ME.
No, it's called people who know what they're talking about.
#33
Maybe I prefer the 4 points of contact that a load leveler gives me? Simply because its easier to grab 1 of 4 chains to help pull an inch or two in either direction.
Wow. I never realized that this thread would devolve into a pissing contest.
Jarhead 74 Vette (12-06-2020)
#34
Other people's work, questionable castings and/or machining abilities I don't. With 500+ pounds of metal dangling over my head, I prefer not to take a chance.
#38
