Single pattern cams
Single pattern cams
I see more posts coming up about using them, I thought that was old technology and using dual pattern was better for making power.
The practice of using dual pattern cams comes from the fact that most cylinder heads have a lousy exhaust port flow compared to intake flow. If the exhaust port flow in in the 80% region of the intake flow, you can cut back on exhaust duration and build more power. There aren't many heads out there with good precentages, the AFR stuff is pretty good.......
based that they are at the very minimum, wouldn't they benefit from a smaller dual pattern?
http://www.airflowresearch.com/index.php?cPath=24_25
some factory heads were better than others, but guys ported heads back then more commonly than today. chevrolet because of input from racers like Smokey Yunick and Bill Jenkins got into hard racing parts more seriously. what we always called the Turbo casting was the first attempt at giving us a decent foundation. plus the layout of the small block sort of dictated to a degree the port size. And remember it was originally only 265 cu,in.
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
This all depends on the RPM range you want to play in also. If you want it to hang on past peak HP...you're going to need some added exhaust duration in most cases.
JIM
JIM
At 75% I/E ratio with a head sized to the CID and rpm application a cam will see the same duration at .050" for both intake and exhaust. Above this the duration will favor the intake. If you look at import cams and cylinder head flow the import stuff is in the high 80's on I/E ratio. Most import cams have more duration on the intake.
As CID grows and rpm grows this rule will change as these demands will change what the engine needs.
