Roller cam infor needed
Old Dec 20, 2014 | 09:09 PM
jez's Avatar
jez
Default Roller cam infor needed
Hi,
I have a 1975 Corvette L82 ( no emissions) 1:3/4 headers true duels (2:5) I am installing a TKO600 trans ( 2.87 first .64 fifth) with a 4:11 differential. I cruise the car at around 2500 with a 5500 redline, basically a street car.
What I presume I need is a cam which wont lug the engine hence needs torque from 1000 to 5000 due to the 4:11 rear gear. I have been looking at howards roller cams ( & am still waiting on feedback from their tech dept) I am also installing AFR cylinder heads 180cc runners 64cc chambers. So who can tell me what the best cam set up is (also 1.5 or 1.6 pushrods) to take advantage of the heads & the gearing I am obviously looking for torque. I doubt I will ever take the car over 100mph as the speed limit here is 75 mph ( I am English living Spain)
I am lost when it comes to cams aside from ( I think from research) I need a hi lift short duration set up. Any information greatly appreciated as this is costing me a lot of $$$ & I want to get it right first time around. Thanks in advance
Old Dec 20, 2014 | 09:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Static compression ratio?
Old Dec 21, 2014 | 05:18 AM
terrys6t8roadster's Avatar
terrys6t8roadster
To answer your ? regarding the best cam choice; the cam grinders them self. With what your building with 4.11 screws that engine is going to be at your red line really quick. SBCs like 1.5 rockers. Also contact Chris @ STRAUB TECH. He's an engine builder / cam grinder with a good rep. T
Old Dec 21, 2014 | 07:16 AM
zwede's Avatar
zwede
Originally Posted by jez
4:11 differential. basically a street car.
This makes no sense.
You sure you actually have a 4.11 diff?
Old Dec 21, 2014 | 09:34 AM
jez's Avatar
jez
Hi,
At present my CR is 9.0 to 1 ( regular CR for the L82) I presume my CR will be raised to 10.5 to 1 using the AFR heads 64cc chambers versus 76cc as I have now. I am no engine builder so am using a mechanic BUT I want to get as much information for the best combination for "seat of the pants" acceleration hence the 4:11 rear gears.
I know my first gear is steep (11.79) but going on the calculators changing at 3000rpm 1st=20mph 2=31 3=43 4=59 5=92 at present with my 4 speed I am at 3300rpm @75mph with the extra gear & a 4:11 I will be at 2500rpm @ 75mph so I gain at both ends although Ist gear may be a bit of an issue.
What I am looking for is 0 to 60 stoplight to stoplight, this is only a weekend car & my dilemma at present is finding a roller cam with correct ratio lifters & pushrods to take advantage of the AFR heads & the gearing I have hence asking you guys for any advice. many thanks.
I forgot to mention my tyre size is 27 inch ( 255/60x15)
Old Dec 21, 2014 | 10:41 AM
TedH's Avatar
TedH
Howards' makes a really good line of retro roller cam kits. I personally went with a Comp Xtreme Energy Retro roller K-Kit as it was very complete and met my performance goals. With 1.52 ratio rockers (see signature), I have relatively high lift of .502/.509 with the duration and LSA of my prior Crane Energizer 272-H10 cam. With your 4.11's and 5-speed with .64 OD, this cam would be in the ballpark of your performance goals; you could probably go 1-2 cams 'down the page'. I would keep max lift safely under .550 to play nice with your stock dimension pistons/valves.
If I were running 'gears' and/or higher stall converter, I would probably opt for the equivalent of the Comp XE K12-432-8. You give up torque for increased horsepower and it all comes later in the power band. This cam is two steps down the page from my K-Kit.
Old Dec 21, 2014 | 11:07 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
http://www.summitracing.com/parts/hr...make/chevrolet
Old Dec 22, 2014 | 11:05 AM
StraubTech's Avatar
StraubTech
With your goal of torque and that head on what I have to assume is a 350CID build it will take a very mild camshaft.
Old Dec 22, 2014 | 11:32 AM
63mako's Avatar
63mako
Hi,
What I presume I need is a cam which wont lug the engine hence needs torque from 1000 to 5000 due to the 4:11 rear gear. Any information greatly appreciated as this is costing me a lot of $$$ & I want to get it right first time around. Thanks in advance
4.11, TKO 600 and fully forged 10 to 1 + compression is a combination begging for a cam that can take advantage of the complete combination. I understand a desire for bottom end power but the gearing will give you all that you need then some. You will NEVER have to worry about "lugging" the engine. Guarantee with that combination you will be incapable of not driving it somewhat aggressively. I recommended a bigger cam because you will be into the powerband so quick no matter what and the combination calls for it. If it was mine I would go solid roller and use the combination to its 7000 RPM potential. Stock L82 has 222/222 duration @ .050. 225/225 Duration @ .050 is not a huge cam when your adding over a full point of compression and the aggressive gearing you have. Operating range 2000-5800 fits your desired cruise of 2500 and 5500 redline but 6000 will be available and I bet used once it is together and your driving it.
To Roller cam infor needed
