Do I need a 'windage tray'?
My old 454 had a windage tray attached via long bolts threaded into the caps. My new short block does not have the extended bolts, so the windage tray will not have anything to bolt on to. Im using a stock GM oil pan that has some kind of internal door/baffle system (its not in front of me right now but I remember saying "ooh, cool, a little flappy door...) Should I be concerned about not installing the windage tray?
If for no other reason than to help keep more oil in the sump (which is reason enough) I'd do what is necessary to install one. Just make certain to re-torque the bottom end properly when you install the necessary stand-off bolts. And, if your new short block happens to have main studs do NOT mix in bolts among them.
the windage tray helps horsepower and keeps oil going where it is supposed to. i recommend using it . i have a 7 quart pan and kept mine.
The bolt kit costs anywhere from 120-180 bucks. I only need the 4 that thread the windage tray. I looked at the ARP site and didnt see that they offered the 4 bolts separately. Im NOT spending 120 bucks for 4 bolts...(studs, whatever)...what else are my options here? Do people choose to omit the tray for any particular reason?
Well, I'd probably be the last one to ask where to draw that line, as I'm including a windage tray, fitted crank scraper, 5-gate RR pan, deburred & Glyptal sealed valley, blended/polished oil galleys, submerged pressure-balanced pump, 3-qt accumulator, hi-flow filtration and thermostatically controlled remote cooler in my 427 redux. So, I may well have spent more on its lubrication system alone than many have budgeted on entire engine rebuilds. YMMV
how about summit racing
http://www.summitracing.com/search/p...-block-mark-iv
Id like to hear more opinions about running or omitting the tray. Ill never see RPM'S higher than 5500, but I do like to launch pretty hard and run it WOT frequently.
Im liking the sounds of that. Is it a drop in part? I looked one up at summit and it looks as if it goes in between the oil pump and cap? Sounds a lot easier than removing main cap rods and such, but Im unsure as to if it will effect the oil pump?
Easy peasy install. Goes between the main cap and pump, and so thin that it shouldn't effect operation unless your pickup height is already critical. Hope that works for you.
Received 1,899 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No....it's a separate piece to keep oil from climbing the back of the pan on hard launches. It's a good addition.
I'd certainly use a windage tray also. There's a reason GM put them in there. With the pan limitations to give ground/steering clearance...the rotating parts can pull oil out of the sump. A great big box stle racing pan with minimal oil in it keeps oil away from the crank without a tray...but you need something in there. Either stock GM or a good pan with internal baffling.
JIM
JIM
You can get pans with a tray built into them. Maybe it's easier to buy a better pan? What pan do you have now? Got pics? The GM LS-7 pan is a great piece and has a trap door. Maybe that's what you have?
GM sells the 4 studs for around $13 each.
JIM
JIM
Ive got a stock GM pan. The pan has some vertical baffles built into it as well as some little one way door. As far as I know its stock. (But as old as the engine.)
