Gas tank straps torque value?
I expect it's about 45 ft/lbs but I can't find it in the Haynes or by searching the internet.
I sure would appreciate some help.
It would be nice to have a list of torque specs for the whole car, 1982 Corvette.
Thx for the help, John
'Tight" is good. Go by the bolt size. If the bolts are 3/8's inch go 30 to 35 lbs. Hell man, it's a C3 vette not an Indy car!
Just busting your chops, don't take it as an insult please.. Nothing wrong with doing things right.
In my 30 plus years of wrenching on everything from street cars to top alcohol funny cars I have never considered torque specs on gas tank straps. Perfection at its finest! You made my evening, my week and my month! I was kinda down but grinning ear to ear now.
If I ever have a race team you WILL be my Crew Chief! I will travel the world to find you.
Received 1,470 Likes
Cruise-In II Veteran
AIMs show torque for specific items. I do not know of a source which lists all C3 torques for specific model years.
Received 2,878 Likes
Hi John,
The AIM lists the torque for the strap bolts as 100-140 lbs.in. (note INCH, not FEET).
The Chassis Service Manual for the earlier years lists many, many torque values for most of the fasteners in the car in it's Specifications section and the AIM does too… perhaps also in those publications for your car?
Regards,
Alan
Haynes is not a good source of information except in the most general way.
Regards,
Alan
Fri-gin hilarious! Gas tank strap bolt torque??
I'm presently doing a frame off restoration on my C3 (Berlina) and I'm concerned that over tightening the fuel tank straps can contribute to the puckering of the bottom of the bladder that results in interference with the sending unit operation.
Most don't know that the bladder type fuel tanks should not be left empty of fuel for extended times. If so it is recommended to remove the tank cover plate and spray the liner with a non detergent 10w30 oil.
Last edited by Charliebates; 04-12-2015 at 10:43 AM. Reason: Edited to make a warmer reply is all.
Hi John,
Regards,
Alan
Regards,
Alan
