filling (4) new calipers, and bleeding - what am I doing wrong??
Maybe, you are smarter than me but I had a hell of a time until I realized there are double bleeders on the rear calipers. all I did was gravity bleed after that. rr inner, rr outer, lr inner, lr outer,rf,lf.
Using a diaphragm type pressure bleeder forces fluid though the system. Pressurize the tank...it applies pressure on the bladder separating the fluid from the air...and attach the correct attachment to the top of the master cylinder....and open the valve...then open the bleeder. Fluid flows out. Then it is up to the person using the tool to keep an eye on the pressure in the tank. Tap on or shock the frame so any bubbles suck to the inside of the walls of the tubing will release and when the fluid coming out of the calipers is clean...you are done.
The diaphragm type pressure bleeder in this video is the type I use.
DUB
Thanks Mr. Dub. When I said Motive was a suction, I meant to say it didn't have a bladder in it. I have an old EIS bleeder with the bladder similar to yours. Has to be over 25 yrs old but still works great. Used it a lot but not many master cylinders. I guess it's to the bench we go first. Didn't mean to take this thread. Thanks.
I've tried both the vacuum method and the pressure method for bleeding brakes. Prefer the pressure method since it does not risk introducing air if the vacuum is strong enough to pull air by the lip seals. I also ran into problems with air being pulled in by the threads of the bleeder when using vacuum. Only issue I have with the Motive Bleeder is the crappy hardware given to clamp the plate to the master cylinder. I finally broke down and bought a large C clamp.
Here's a link to a video I found helpful. Tried this out yesterday. Had to jack the rear of the car up pretty high to get the master cylinder angled slightly downward toward the front. Got the last few bubbles out of the master, now have a hard pedal.
