Stripped seat mount nut
A couple of my seat bolt nuts appear to be stripped on my 68. Is there a different bolt size or anything to try?
Received 3,139 Likes
How bubba are you
Install a longer bolt and put a nut underneath
Drill it out and tap to the next size bolt
Drill it out and installing a thread insert (or helicoil but that needs special taps etc) will keep the size as the original bolt and maintain strength
Replace the panel with a new one.
Personally I went medium-light Bubba and installed a thread insert when I found the rear-outboard thread was stripped on my passenger seat (and bubba before me had installed a longer bolt and nut)
M
M
My 81' pax. side seat has a stripped nut...the temp. repair is a longer bolt and nut...the permanent fix is a helicoil (or similar)...the kit contains the drill, the tap and several inserts, for about $18.00 at most auto parts places...Good Luck
Sounds like the best way to go is either tap to next bolt size or use an insert. I'll decide between those two options. Thanks!
http://www.timesert.com/
