Recommendation for fan clutch replacement
It's time to replace the fan clutch on my 1972 350 (base engine) with A/C. Does anyone have any recommendations for a good replacement?
AC Delco part number 1580275
Hayden makes a pretty good replacement thermal fan clutch as well. One thing to consider is that there are essentially three versions of the typical thermal fan clutch; Standard Duty - turns the fan at 60-70% of shaft speed when engaged, Heavy Duty - turns the fan at 70-90% of shaft speed when engaged, and Severe Duty - turns the fan at 80-90% of shaft speed when engaged.
There's some pretty good info here regarding thermal fan clutches that you may find helpful regardless of the brand or vendor you purchase from.
http://www.haydenauto.com/featured%2...s/content.aspx
Good luck... GUSTO
Good luck... GUSTO
