Suffix V0223TBC ??
Suffix V0223TBC ??
Hi
A friend has a 73 Vette with an engine Suffix is V0223TBC block 3970010.
From what car is this engine because TBC is not a Corvette Suffix ?
And may be one also nows the engine details, like HP rating etc.
Thanks and brgds. Günther
The "T" indicates a truck engine.
TBC 1970 350 convfwd cabs, a/t 255hp 4bbl C-10 to 3500
TBC 1970 350 m/t, 3 spd 255hp 4bbl K-10 & 20
TBC 1979 350 conv. cab, m/t,fed L LS9 165hp 4bbl C-10 to 2500
Hi
Some more questions, pls :
the stamped VIN beside the Suffix is C9F16152.
Any idea to which of the 3 possibilities this points to ?
What does C10 to 3500 mean ? C10 is a date, but to 3500 ?
And shouldn't truck engines be tall deck blocks ? The 3970010 block is a pax car block also used in Corvettes.
Or is this casting # also produced as tall deck ?
Wbrgds. Günther
Wbrgds. Günther
C10 was the designation for a Chevrolet 1/2 ton pick-up, with rear wheel drive. 2500 and 3500 indicated a 3/4 and 1 ton truck, respectively, though I think they were actually marketed as C20 (3/4) and C30 (1 ton) at the time. The same designations were used with a "K" in front of them, when the truck was equipped with 4 wheel drive: K-10, K-20 & K-30.
Wbrgds. Günther
Wbrgds. Günther
