81 Corvette Stoker Kit
Old 08-31-2015, 08:29 PM
churley8770
1st Gear
churley8770's Avatar
Default 81 Corvette Stoker Kit
Hello everyone,
I have an 81 Corvette that I am about to install a 383 stroker kit on. I am trying to find out what type of oil pump I need for the system. Can I keep the stock volume oil pump on there, or do I need a high volume? I have heard horror stories about both. I don't plan on racing it or anything like that, just having some fun on the street.
383 stroker kit
stock heads (all new internals)
comp cams street performance camshaft
Weinan Street Warrior Intake
Edelbrock Performer 750cfm carburetor
Thanks for your input!!!
Old 08-31-2015, 09:01 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
You absolutely can keep the stock volume pump. I'd probably go with a new one with a new build, but you'll be fine otherwise. Good practice to replace the pump drive a metal collared one too.
Old 08-31-2015, 09:39 PM
TimAT
TimAT's Avatar
You'll get 900 opinions. Myself, I like the GM 3848907 pump. Number may have changed but it's the Z/28 pump from years ago. Replacing it is pretty cheap insurance for a new motor.
Old 08-31-2015, 09:52 PM
ddawson
ddawson's Avatar
New, and I'd use high pressure not high volume pump.
Old 09-01-2015, 08:57 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yeah the Z28 pump is what you want
Old 09-02-2015, 03:57 PM
toobroketoretire
toobroketoretire's Avatar
A stock pump is all you need unless you're planning on beating on it on a regular basis.
Old 09-04-2015, 06:51 AM
worship79
Support Corvetteforum!
worship79's Avatar
I'm using a Melling 55HV pump. Pressure is a tad on the high side, so if you can I'd start with stock.
Little tip on your build; don't forget your oilpan may not clear the longer stroke crank.
To 81 Corvette Stoker Kit
Quick Reply: 81 Corvette Stoker Kit
