71 Accessory's and windows always powered.. draining battery
My 71 conv. requires a manual battery disconnect because the power is always hot to the radio and windows even after the key is removed.
This thing needs a complete rewire, but is there something simple-ish, for me to look into that might be simple for now?
-There are no switches on the door, which I would imagine should be there to cut the power after opening the door. (My modern cars work this way)
A previous owner just changed the wiring around so he could listen to his radio and power his windows up and down without having to turn the key ON. I did the same thing to my '71 right after I got it because its a lot handier to be able to operate both with the key OFF.
For safety reasons G.M chose to allow power to the windows only when the key was on to prevent a kid from getting into the car and hurting himself or his little sister with the powerful power windows.
What does your fuse panel look like? I am going by my 69 which might be similar.
You should have an ACC tab in the middle of the fuse panel. This tab should have your power window harness plugged into it NOT the BAT or IGN tab. (again ... this is how the 69 is done I dont have a 71 wiring diagram)
The power windows are an add on harness that is supposed to be plugged into the ACC tab so that its only hot when the key is in RUN or ACC.
Is the radio aftermarket? Sounds like it wired to the wrong circuit as well. I would trace it back and see where the radio is connected to. Cant really tell without more info.
Received 1,246 Likes
The pink/black for the power windows plugs into the IGN terminal.
The 71 schematic does not have a PW diagram so use this one.
http://www.vetteprojects.com/bmv/mis...tte%201974.pdf
71 Schematic;
http://www.vetteprojects.com/bmv/mis...tte%201971.pdf
71 Schematic;
Received 3,220 Likes
I'd start looking at the ignition switch- Mounted on the steering column- controlled by a rod - so you don't need to take apart the column. The rod/switch might just be messed up. Disconnect and check the power at the wires w/ diagram below
Wires/ diagram at the switch-
starter wires by Richard Hayes, on Flickr
The ignition switch
DSCN5206 by Richard Hayes, on Flickr
DSCN5195 by Richard Hayes, on Flickr
Rod that controls the switch
DSCN5205 by Richard Hayes, on Flickr
Wring harness for ignition switch
DSCN5194 by Richard Hayes, on Flickr
The ignition switch
Either your ignition switch has been re-routed intentionally....or it has failed and needs to be replaced.
