Body Off
Body Off
Guys,
Thinking about taking body off my 79, other than seats, what else should come out of the interior if taking body off. This is a running car that I am about to swap out the engine on and I was thinking about going ahead and restoring the running gear as well. I know probablt a PIA, but i've got all winter...thoughts????
Guys,
Taking the body off leads to the "while I'm at it" syndrome and the next thing you know your doing a full out rest / resto-mod and several years have passed.
Again, unless the car needs more, or you plan to go that far, just do what you need to do the way it sits. There isn't really anything that is too difficult to access with the body on. That will also guarantee you have a driveable car to enjoy come spring.
Cruise-In IX Veteran
There are a lot of things to remove. The seats though is probably not one of them. You will have to remove the seat belts though. And here is a list of things I can think off from my 71. They may not apply to a 79.
Wiring grounds
Battery connections
Engine harness
Speedo cable
Front and rear bumpers
Bumper supports
Oil pressure line
Brake lines from master cylinder
Radiator support bolts
Parking brake cable
Vacuum lines
Basically everyone connected to the engine needs to be disconnected. You may also have issues with the 8 body mount bolts depending on rust and corrosion.
Wiring grounds
Battery connections
Engine harness
Speedo cable
Bumper supports
Oil pressure line
Parking brake cable
Vacuum lines
For a 1979...Seat belts do not need to be removed...the floor pans are different.
Steering column at gear box
Fan off of engine.
Fan shroud
Radiator (to save on weight)
Oil pressure sensor wire ( does not use a line like earlier Corvettes)
Heater hoses
Wiring to your HEI distributor.
Starter wiring
A/C compressor wiring
Ground wire at starter or transmission bolt. ( Small black wire)
Accelerator cable
DUB
Fan off of engine.
Fan shroud
Heater hoses
Starter wiring
Accelerator cable
DUB
thanks for the responses...i was just concerned about the weight of the body w/doors/glass/door panels and the like. I can see how it could turn into a "while i'm at it" thing, but i guess that would be "the" time to do it. Thx again for responses
You can lighten the load by taking otu as much as you like...I do the same thing....no battery, seats door panels. Anything that can come out rather quickly. I leave the doors on...but the T-tops can come out.
DUB
DUB
