Correct Ignition Key Warning Buzzer Installation?
I'm working on the interior guts of my T&T column on my '81. I was installing the key buzzer switch where one was missing. I can't find a good clear picture of the part installed in the column. I installed the part as I thought it should go. Here is a picture of how I installed it. Please tell me the correct orientation if this is not correct. I'd say the clips are at 11 o'clock and the squared off side is at 3 o'clock in the photo.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This is from a 77 column.. slightly different but you got it in the right place.
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdfThis write up was by far the best, I found and the pictures showed everything I needed to do my '78 Good luck
Street Rat (02-10-2016)
I have certainly learned a bunch about Corvette T&T steering columns.
HATS OFF to you guys that work on these things on a frequent basis. I have a new found appreciation for those who tackle a R&R on one of these columns.
