heater hose question
Am in the process of swapping engines (c4 lt1). Need to reposition the heater hose lines (from the heater core to the water pump) - Does it matter if the 2 hoses from the heater core lay secured on the frame rail (and then attach to the water pump) Or do they need to be upright position due to the inline heater check valve?
Any idea?
Any idea?
Does not matter. I am assuming that the check valve you are referring to is actually the hot water shut off valve.
DUB
DUB
Thanks DUB, yes the hot water shut off. It wouldn't be completely flat against the frame, maybe 25% would rest on the frame as it inclines to the water pump.
Just make sure ....because it seems that this is a CUSTOM engine install scenario.....so...keep in mind 'movement' ..'accessibility to the part for future servicing' and trying to make it so the heater hoses are somewhat secured and can not flop around and rub a hole in them in the future. NOT writing that you had not considered what I just wrote.
For what it is worth: On some of the custom engine jobs I work I will slide on some of the woven black shielding material to help protect it....and in some areas I even use the black plastic split loom material for wiring harnesses.
I never use the stainless steel sleeving material on heater hoses and radiator hoses. I just do not like the look. To me it never fits snugly and looks cheap like I am trying to 'look' like eh real stuff is being used....but not wanting to take the steps to actually do it. I prefer to use the REAL stainless steel braided hose. But that is just me.
DUB
DUB
