Dash Lights, are dim.
My 75 Vette has been stored for 26 years and I recently got it back on the road.
I noticed that all the dash lights are very dim at the highest level, could this be a result of every bulb becoming weak after not being used for so many years, or maybe a bad contact in the headlight switch. The lights dim when I turn the headlight switch but it goes gradually from 0% to 50%. All bulb are the same intensity across the whole dash and center dash section. I was also thinking maybe a weak ground?
Any thoughts.
Any thoughts.
Received 1,246 Likes
To bypass the rheostat:
You can jumper from the 'courtesy light fuse' to the 'instrument light fuse' and if the bulbs get brighter then the rheostat is bad.
Our instrument lights are not as bright as the new cars.
The following 2 users liked this post by Peterbuilt:
JavaJolt78 (06-06-2023),
Maymyvetteliveforevr (03-30-2016)
Thanks for the reply Peterbuilt
When you say "jumper", I assume that means place a fused wired after the courtesy light fuse to before the Instrument light fuse. This way you're providing full power to the dash lights and bypassing the rheostat which acts as a dimmer switch for the dash lights?
Maymyvetteliveforevr (03-31-2016)
