Oil filler cap will not lock in place
I have a small block LT1 with the original finned aluminum valve covers. The oil filler cap (with the stamped 'S') does not lock in place. After inserting it into the valve cover opening and rotating it CW, I feel a bit of resistance but then it spins further and becomes lose. The rubber gasket on the inside of the cap looks fine.
Any suggestions how to fix this so the cap locks in place? Thanks.
Bandit 00C5 (08-02-2020)
Received 2,878 Likes
Hi s,
I don't see any clues as to what year your LT-! is.
70 valve covers were designed to use the twist in type of cap you describe.
71-72 LT-! valve covers were designed to use a push-in rubber oil fill cap.
Are you using the right cap for the valve cover design?
If you are, have you tried to run your finger around the inside of the oil fill opening to see if the 'ramp' that acts as a stop is intact?
Regards,
Alan
Regards,
Alan
Hi s,
Regards,
Alan
Regards,
Alan
I just checked the inside of the oil fill opening and found it to be totally flat. There is only a uniform 'collar' along the inside of the perimeter of the opening. There is no ramp, all uniform height.
The picutre below are NOT my valve covers but a photo off the internet. This is how my valve cover opening 'collar' feels. Mine does have the short raised bump up on the ends of the collar as in the photo example. Perhaps you have a suggestion. Thanks.
Hi S,
Is it possible that the raised 'stop' at the end of one or both of the ramps are worn down so the flanges on the cap ride right past them as you turn and the cap is then able to slip out?
If you turn the cap just the length of the ramp (by guessing how much that is!) does the cap feel tight enough to stay in place?
Are the 2 'flanges on the cap bent the 'wrong' way even a little? Could they be bent some so they're tighter against the ramp when you insert it in the hole and first begin to turn it?
Regards,
Alan
Regards,
Alan
Hi S,
Regards,
Alan
Regards,
Alan
Today, I ordered a replacement 'original' oil cap ('S' stamp) which I should receive in a few days. I am hoping that the new cap will lock in place. This is a very peculiar problem. However, maintaining a proper oil cap seal is absolutely vital. Thanks again.
Hi S,
Well, that's good to hear!
I'm not sure just how accurate the reproduction caps are, so you might want to still hang on to the one giving you trouble in case it's the original.
It's configuration might mean something to someone someday.
Regards,
Alan
Regards,
Alan
