New Engine Build
New Engine Build
Hey everyone I'm new here and my knowledge on engines is quite limited so no rude comment or anything. I have a 1979 vette and it has the L82 engine. I want to build a engine and swap it. I am looking at building a 383 or a 454 from ATK performance engines. any tips or suggestions? I want to get around 450HP. I would get a short block and build the rest of it. what are your suggestions for an aggressive engine performance and sound. Thanks!!
So are you looking at building an engine or buy a crate? Not being a smart a$$, but the 383 and 454 from atk are probably crate engines although I'm sure they'd sell short blocks or parts for that matter. Crate is a good way to go but I get more satisfaction doing it myself. Now then a 383" is a small block and the 454" is a bigblock your L82 is a small block as well and it would be easier to swap small blocks, but the 454 would probably make your grin bigger. Let's start with a few questions:
1)what transmission?
2)what's your budget?
3)what's the majority of your intended use?
4) what rear gears do you have? ( most engines that build decent power have larger camshafts and lower gears enhance the driving experience a lot when matched with the rest of the combo, same goes with a torque converter when you have an automatic transmission as it needs to match the camshaft and rpm range)
5) are you mechanically inclined and do you own tools?
Thanks for the reply.
I have the
TH350 transmission
$5000-$6000
weekend driver and some strip
I'm not sure what my gear setup is. how can I find out?
I am still new to working on engines but I want to learn more and how to build. there is a shop near me where I can use their lift and all their tools for $5 a hour.
I have the
TH350 transmission
$5000-$6000
I have the
TH350 transmission
$5000-$6000
I have the
TH350 transmission
$5000-$6000
Go big , put a 632 bbc in her that idles well uses 91 octane gas and has 850 hp .. LMAO .
Received 3,043 Likes
St. Jude Donor '05
5-6 do the 383
Otherwise youll need to upgrade exhaust brackets cooling system etc cost will spiral quick. 450 is real easy to get with a 383 and still be driveable without winding it up to the moon (or your wallet)
diehrd (06-18-2016)
