Key Cylinder Problem
Received 3,139 Likes
If you look at one of the "sticky" threads at the top of this forum there is a thread on problem tumblers. Your's may be the same issue, frequently the column doesn't rotate quite far enough when the shifter is moved to let the key release.
https://www.corvetteforum.com/forums...lfunction.html
M
M
brian76 (05-29-2016)
This is the link to the sticky on the General Motors Steering Column/Transmission Shift Interlock System. The information is correct for C3 Corvettes from 1969 thru 1976.
Jim
Jim
