68 Windsheild wipers shorting out
When I turn on the wipers there's power on the wiper arm! I was out for a drive started raining get out to pump gas I noticed when the wipers were sweeping the blade would come into contact with the windshield molding and it arcs! Any ideas? Tested with volt meter there's 12 volts on the wiper arm
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Missing ground is possible.. I'm out of town until tomorrow but will take a look at this Monday
Dementer sole survivor
Received 6,294 Likes
2016 C3 of Year Finalist
The 68 system is backwards from the other years. Always has 12 volts looking for ground. Im sure wilcox will have your answer. I would look at the wiring around the motor to see if anything is bare, broken or disconnected. You could do wilcox bench test to see if anything turns up as well.
