engine runs too cool
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
The T-stat does NOT set the operating temps of the cooling system; it merely sets the temp at which the stat will begin to open. The cooling system will continue to heat until it reaches ITS equalization temperature. You can run with no thermostat, and the final stabilized temps of the cooling system will be the same as if it had a 195*F stat in it. It will just take a lot longer to get there.
The ts gradually begins to open prior to reaching its designed rating of say 180* At 180*, the ts is fully open allowing coolant at 180* to enter into the rad. The rad cools the coolant and it re-enters the engine to get re-heated to 180* controlled by the ts's throttling action. If the engine can't heat the coolant to 180*, the ts will not open, such as when the coolant is cold on startup. A properly sized and functioning cooling system will maintain the temperature at 180* regardless of outside air temp. If the coolant temperature cannot be maintained at 180* and rises above that, then the radiator is most likely not designed to handle the cooling requirements in the ambient conditions. Now throw in an A/C system with a condenser in front of the radiator. This will put an additional tax on the radiator and can cause the coolant temperature to rise entering the engine. The GM engineer's only have so much room to work with sizing a radiator and selecting an acceptable material to build them so there is a trade-off in cars running warmer with A/C systems in general but maybe not so much these days e.g. better designs, materials. I don't know GM's design criteria for radiators but I'll guess it's designed to function properly in ambient air temperatures of -50*F - 120*F which would cover about 99% of all expected operating environments. Now, you could take the ts out and the engine will find a normalized temperature but only at that ambient air temperature. As the ambient air temperature fluctuates, so will the coolant temperature. Also, ever see the big rigs with covers over their grilles in the winter? They do this to prevent cooling the coolant in order to maintain a proper coolant temperature in the engine. Remember, too cool an engine operating temp reduces the oil's lubricity leading to increased engine wear.
The following 2 users liked this post by resdoggie:
chevymans 77 (12-06-2016),
shenango (12-10-2016)
Chevy designed the SBC engine with a 180*F T-stat. 195*F stats were only required after emissions requirements were established. More hydrocarbons are burned off when the engine operating temps increase. But, of course, TOO hot is not good either. Car companies agreed to install 195*F stats...but they weren't happy about it. More engine problems (idle quality, warranty, etc), lower fuel mileage, and some other minor issues were negatives related to stat (and operating) temps higher than 195*F. So, from a "customer's" standpoint, a 180*F stat and stabilized operating temps not much above that level are what Chevy intended with the SBC engine.
resdoggie:
You have a general understanding of the cooling system, but what you are missing is that the thermostat is ONLY there to speed the engine's heating up to the temp of the stat. If you have over-engineered a cooling system (too large a radiator, etc), then the stat CAN set the systems temps and it will regulate open/close to keep it there.
But, by design intent, the stat...once it is fully open...is to stay in the open position (completely) and the SYSTEM will regulate its own temperature based on how much heat is generated (by engine) and lost (to the environment). If designed properly, that stabilized temp will not be much higher than the stat temp (maybe 200*-210*F in hot conditions).
If the stat were to ALWAYS regulate the system temps, the pivots on that chinzy stat would wear out in short order. No, it is SUPPOSED to stay open, once the engine has warmed.
gungatim (12-05-2016)
resdoggie:
The thermostat serves two functions:
1) speed up engine warm up to operating temperature
2) temperature regulation by continuously allowing/restricting coolant flow to keep the engine operating within its optimal heat range.
For the OP: it sounds like your thermostat is stuck in the open position.
The primary source of dumping heat from the engine is via the radiator. As coolant temps increase, the temperature drop as coolant passes through the radiator also increases, thus regulating/managing engine temperature. You can believe that the T-stat "controls" engine temperature...but it doesn't; it merely 'modifies' it.
If the T-stat did the 'controlling', how would it manage rejecting more heat once it was fully opened? [ie, hot summer day with air conditioning on HI and car idling] Obviously, it can't; the radiator/fan does that job.
Obviously, If the cooling system is incapable of reducing the coolant temperature below the thermostat design limits (due to poor design or malfunction (fan/belt/radiator/etc) then the thermostat is useless.
Based on the OPs description the motor is not reaching the desired operating temperature - the thermostat is likely stuck open.
Royal Canadian Navy
Thermostats don't cool anything - they regulate the flow of coolant based on temperature of the coolant to a desired operating range - nothing more.
about a month or so ago my original radiator on my 72 ,350,4 speed started leaking. so I replaced the radiator with an aluminum one from champion. I also put in a new water pump , the stock cast iron type. I also changed all the hoses and clutch fan, belts etc. I had already been running a new fail safe 185 degree thermostat.... before the repairs my car would run in the 185/195 range. I have a temp gun that ive been checking it with because after the first test drive I thought my gauge had broken. not true. 20 mile run and the temp at the radiator, gauge and water pump was around 117/ 125. ok so heres the problem. if I crank it up and let it idle I can watch the choke open all the way. when I go down the road and its cool outside 50/60 degrees the choke will close because its cooling off too much. when I filled the radiator I put one gallon of anti freeze and the rest water. I live in east texas and it never really goes below 25/30 degrees here during the winter if that, plus my cars are all kept inside my shop so what did I do?
Have you installed a new t-stat yet?
The thermostat will "set" the minimum operating temperature of the engine. The efficiency of the water pump and radiator will "set" the max temp. Don't overthink it. A 180 stat is a good choice for our 40 odd year old machinery. Install one and be happy.
there is a little more than just removing 2 bolts, the liquid is the worst part to drain and refill without an airpocket. IMO and the bolts can sieze and brake off causing more problems.
One thing I learned that might be old news to many, is I did the stat on the stove in hot water experiment. The stats actually open up pretty slow when they reach their set temp. They don't just pop open fully allow maximum flow at the set temp. Can't remember the one I got from Pep Boys, but its us made, and it actually starts to open at 170 and is about fully open at 180. I recently pulled intake to replace gasket, was getting oil from sides. Thats another post. Anyway, ever since I put it back on, temp would get up to almost 190 on gauge before stat was opening fully. Before I pulled intake, I could watch the stat open on my temp gauge, it wold get up to about 183 or so and then it would drop to 179/180 and stay there as long as I was moving or fans were running.
Figured I got a airpocket in system. Tried different 180 stats all same results. Drilled 3- 1/8 " holes in a high flow stat and that solved the problem. Was always against doing that, but I could not get it to operate the same prior to pulling intake. Of course now its colder out. Temps stays steady at 178-180 at cruising speed. I have a L88 hood that is not sealed properly across the top, probably getting a lot of air flow over the rad.
Dewitts rad, with spall electric fans. AutoMeter Mechnical Water temp Gauge.
#33
Agreed. I syphon a few inches out the rad before removing stat housing to avoid a dripping mess. Its a PIA...
#34
