Can front diff mount be removed with suspension loaded?
I'm getting ready to do an in-car pinion seal replacement and it looks like time well spent to remove the front diff mount to gain better access. I plan to do this on my 4 post lift with the weight of the car on it's wheels. Can you remove the front diff mount with the suspension fully loaded or will the diff rotate up and possibly tweak the crossmember? Thanks.
Thanks. If you had to do it again, would you remove the front mount to get better access to the yoke and seal or try to work around it? I've only done this on live axle cars with lots of room in that area.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Why not just take a few minutes ahead of time and jack up the frame at the rear (just ahead of the wheel wells), and put some wood blocks there to take the weight (and twisting force) off the rear spring?
I was removing the driveshaft for balancing and u joints but the front diff mount should be removed. It is only a 10 min job and gives you easy access to everything. Check your rubber mount cushions for wear at the same time and don't forget a couple of new cotter pins for the 2 horizontal bolts.
I'm on a 4 post lift with no good way to jack the rear and place jack stands. I really don't want to do this job off the lift if I can help it. I do have pole jacks but that seems like a Darwin award winning move.
Did your C3 come without a scissor jack, cuz they're incredibly handy for lifting a Corvette up by the frame.
You have to block it up anyway to keep it from moving or rolling on your hoist when you disconnect the driveshaft so a couple of blocks at the rear frame pockets is a very good idea.
On my Camaro, when I remove the driveshaft, I chock the wheels and set the parking brake. For the Corvette, I'm gonna take another look at how the frame aligns with the lift to see if I can get some jack stands under it.
The frame pockets just in front of the rear wheels line up with the tires so if the tires are on the lift, jack stands will fit no problem too.
But, your call.
