C3 1976 Fuse Box
Old 12-11-2017, 05:59 AM
Claudio Silvreti
Claudio Silvreti's Avatar
Default C3 1976 Fuse Box
Hi, Best overseas friends,
There is an expert who can explain me what fuses these are?
I have no dashlights working. I have numbers added.
Thanks fo ryour help.
salruiz (09-03-2023)
Old 12-11-2017, 07:26 AM
NeverTooOld
NeverTooOld's Avatar
Your headlight switch's **** MAY be rotated all the way to the right (clockwise) which would dim your instrument lights so much they aren't glowing at all. Try turning your headlight **** counterclockwise and see if your instrument lights come back on.
Old 12-11-2017, 07:38 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Claudio,
It might well be the headlamp switch as NTO described... if it's the fuse, it would be the one you numbered #7.
Regards,
Alan
INSTrument/LamPS
Old 12-11-2017, 08:04 AM
Claudio Silvreti
Thanks Alan,
Great info, I will see it tomorrow, now it's heavy snowing in Belgium, so I can not go to my Corvette at this moment.
Best Regards.
Old 12-11-2017, 08:44 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Make sure when you check the fuse to also test the passenger side terminal for power. It's possible the terminal is corroded and not passing current. While the fuse can test good, the corrosion can prevent it from working.
Here is a picture on how the system works, it may help you diagnosis your issue.
Old 12-12-2017, 12:43 AM
Claudio Silvreti
Hi, I really appreciate your answers. Does anyone know where the other fuses are for? 2nd question: what is the ideal tire pressure, front and rear? (Stock tires Goodyear Radial GT) You help me a lot.
Regards Claudioģ
Old 12-12-2017, 12:57 AM
Greg
Just another Corvette guy
Support Corvetteforum!
Greg's Avatar
Received 3,836 Likes on 1,783 Posts
Why is this diagram showing and ECM fuse and a Choke Heater fuse for a 1976?
Old 12-12-2017, 01:39 AM
Claudio Silvreti
Its just a clear picture from the internet.
Choke and ECM are not necessary.
Greets, Claudio
Greg (12-12-2017)
Old 12-12-2017, 11:41 AM
0Willcox Corvette
Former Vendor
If needed, here is a picture of the factory 1976 fuse panel.
Willcox
To C3 1976 Fuse Box
Quick Reply: C3 1976 Fuse Box
