Big-Block "casting #" location on the block???
Old 11-07-2002, 10:53 PM
NASCAR314
NASCAR314's Avatar
Default Big-Block "casting #" location on the block???
Where would you find the casting number on a big block Chevy motor?
71-72 454c.i in question.
Thanks,
Tom
Old 11-07-2002, 10:58 PM
73 LS-4
73 LS-4's Avatar
Default Re: Big-Block "casting #" location on the block??? (NASCAR314)
Hey Tom,
It will be on the drivers side of the block just behind the cylinder head, I'm guessing this is for your new toy?
:cheers:
Pat Kunz
Old 11-07-2002, 10:59 PM
LAvetteman
LAvetteman's Avatar
St. Jude Contributor
Rear, by bell housing, drive side, 7 digits. Post what you find, we have references.
Old 11-07-2002, 11:52 PM
NASCAR314
NASCAR314's Avatar
Default Re: Big-Block "casting #" location on the block??? (71,454,4spd)
Yes Pat, it's the motor in the "New Toy", I'm still un-ravelling the mystery!
Casting # 3999289 (or maybe 8999289)
Thanks for the location, easy to find when I know where to look.
The cast iron exhaust manifolds match up to a 1972 model Chevrolet.
(#3989310 on right and #3989343 on left)
This motor is not in a Vette, just wondering what it came out of originally.
Thanks,
Old 11-08-2002, 12:24 AM
73 LS-4
73 LS-4's Avatar
What a coincidence, you have the same casting I do :lol: 3999289. So it may possibly have been out of a 73 vette, when you get a chance pull a valve cover and see if it has 049 heads, if it does then there is a better chance it did come out of a 73 vette. What vin number is stamped on the block in front of the passenger side head?
:cheers:
Pat Kunz
Old 11-08-2002, 12:41 AM
LAvetteman
LAvetteman's Avatar
Didn't see it, here is where I look.
http://www.nastyz28.com/sbchevy/sblock.html#casting
Old 11-08-2002, 07:12 PM
NASCAR314
NASCAR314's Avatar
That link is for "small blocks"
Need the "Big block" info.
Pat, I'll get back to ya with the V.I.N.# and head castings when I get time to check.
Thanks,
Tom
Old 11-08-2002, 10:01 PM
LAvetteman
LAvetteman's Avatar
Wooops, sorry. There it is, says its a 2 bolt for car or truck.
http://www.nastyz28.com/bbcmenu.html
To Big-Block "casting #" location on the block???
Quick Reply: Big-Block "casting #" location on the block???
