What makes a starter just go clunk?
Old 06-24-2003, 03:49 PM
Fevre
Fevre's Avatar
Default What makes a starter just go clunk?
Damn Formula is doing its best to stay out of the heat, bypassed the stupid Passkey system so I think my intermitant no crank problem is fixed but after trying to start it once and running the batt down it now only makes a clunk sound when I try to start it after batt recharge? Just glad it died after I got the vette going.
Old 06-24-2003, 04:34 PM
pws69
pws69's Avatar
Default Re: What makes a starter just go clunk? (Fevre)
Possibilities:
Corrosion on the battery cable connections.
Bad solenoid (i.e. the copper disc has arced too many times and no longer makes contact).
Battery could be toast - need a load tester to determine (yes, it can appear to take a full charge and be junk).
Starter motor could be toast (if you heated it up too much when trying to start it before, you could have melted the solder inside).
Old 06-24-2003, 04:57 PM
Fevre
Fevre's Avatar
Default Re: What makes a starter just go clunk? (pws69)
All are def possiblities except the corrosion. Good excuse to buy a new mini starter.
Old 06-24-2003, 06:30 PM
Fevre
Fevre's Avatar
The old :smash: with a hammer trick worked! First time I ever tried it. Now to figure out why no spark. :mad
To What makes a starter just go clunk?
Quick Reply: What makes a starter just go clunk?
