this is what the Cam companies suggest what do yall think?
I called three cam manuf. today below is their recommendatins what do you guys think? first here is some info on my engine
BLOCK:
454 cid
compression = 9 to 1
ROCKER ARM ARTIO: 1.7
HEADS:
gm #3909802
oval port, closed
101 cc
INTAKE:
gm# 3947801
CARB:
edelbrock #1910 850 cfm vac. secondaries
EXHAUST:
hooker side pipes w/ glass packs
3.70 gears and stock th350 transmission and torque convertor
HERE ARE THEIR CAM RECOMENDATIONS
CRANE RECOMENDATION
Application Series & Grind Number 103072
Fair idle, moderate perf. usage, good mid-range to upper RPM torque and HP, mild bracket racing, auto trans w/2500+ converter, 3000-3400 cruise RPM, 9.5 to 11.0 comp. ratio advised. Basic RPM 2500-5500 Energizer
282 H08
Cam Specifications
Degrees Duration @ .050 Int./Exh. 226/226
Degrees Advertised Duration Int./Exh. 282/282
Degree Lobe Separation 108
Gross Lift Int./Exh .533/.533
CRANE RECOMENDATION
Application Series & Grind Number 103052
Good idle, daily usage, good mid-range torque and HP, off road, highway towing, fuel efficiency plus performance, 2600-3000 cruise RPM, 8.75 to 10.0 compression ratio advised. Basic RPM 2000-5000 Energizer
272 H10
Cam Specifications
Degrees Duration @ .050 Int./Exh. 216/216
Degrees Advertised Duration Int./Exh. 272/272
Degree Lobe Separation 110
Gross Lift Int./Exh. .515/.515
COMP RECOMENDATION 4X4 XTREME
Application Series & Grind Number 11-235-3 grind 262h
Cam Specifications
Degrees Duration @ .050 Int./Exh. 218/226
Degrees Advertised Duration Int./Exh. 262/270
Degree Lobe Separation 111
Gross Lift Int./Exh .505/.515
Application Series & Grind Number 11-239-3 grind 270h
Cam Specifications
Degrees Duration @ .050 Int./Exh. 226/234
Degrees Advertised Duration Int./Exh. 270/278
Gross Lift Int./Exh .544/.564
CROWER RECOMENDATION
Application Series & Grind Number 01904 grind 292H
Cam Specifications
Degrees Duration @ .050 Int./Exh. 214/224
Degrees Advertised Duration Int./Exh. 292/302
Degree Lobe Separation 112
Gross Lift Int./Exh. ..503/.529
BLOCK:
454 cid
HEADS:
gm #3909802
oval port, closed
101 cc
INTAKE:
gm# 3947801
CARB:
EXHAUST:
CRANE RECOMENDATION
282 H08
Cam Specifications
CRANE RECOMENDATION
272 H10
Cam Specifications
Cam Specifications
Cam Specifications
Cam Specifications
Location: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Re: this is what the Cam companies suggest what do yall think? (ykp53)
I would go with Comp.
I just sold a 79Z with a sb400. I ran a Comp Extrem 294, with a holly 850.
It was a real fast car. :D
I'd go with the Comp Cams 270/278 with the 1.7 rockers. It should be mild enough for the street, but with enough guts to have fun at the track.
