What headers work with angle plug heads?
Old 02-15-2004, 12:00 AM
STLBLUES
STLBLUES's Avatar
St. Jude Donor '09
Default What headers work with angle plug heads?
I have the stock 82 headers/manifolds on trick flow alum. heads. Do you have to run a specific header with angle plug heads or do you just buy a header for a 63-82? I am looking for a ceramic long tube header that fits the angle plug heads and the spark plugs will still be removeable. Or do I need a shorty header? I probably will never run them open at the track either way.
Thanks for the help, Steve
Old 02-15-2004, 08:08 AM
mrvette
mrvette's Avatar
Default Re: What headers work with angle plug heads? (STLBLUES)
Get a set of Schoenfeldheaders.com #151 under 'chassis' heading....
for 150 bux at your door, you got a nice set of headers, send them off for ceramic coating at your local place, then put on the car....clear plugs fine, and the tubes are not constantly in the way of everything else....
GENE
Old 02-15-2004, 08:57 AM
Fevre
Fevre's Avatar
Dynomax ceramic coated headers work well, there are a couple tight plug clearence but I have had no problems with burnt boots.
BTW I am running trick flow heads also.
[Modified by Fevre, 9:01 AM 2/15/2004]
Old 02-15-2004, 10:05 AM
STLBLUES
STLBLUES's Avatar
St. Jude Donor '09
Thanks,
I will check into both. How much does ceramic coating run if you already have a set? - Steve
Old 02-15-2004, 10:31 AM
Ganey
Ganey's Avatar
Default Re: What headers work with angle plug heads? (Fevre)
Get Dynomax Cerma Coat headers.
PS Would not use the 151.
[Modified by Ganey, 9:35 AM 2/15/2004]
Old 02-15-2004, 04:42 PM
thevetterisbetter
thevetterisbetter's Avatar
Default Re: What headers work with angle plug heads? (Ganey)
I have dynomax with angled plugs on AFR heads, no problems.
Old 02-15-2004, 05:36 PM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
Default Re: What headers work with angle plug heads? (thevetterisbetter)
I'm currently running Sportman II's with Hooker Super Comp sidem ount headers. I've got my fingers crossed that my new AFR's will work with these headers also ;)
Old 02-17-2004, 07:08 AM
UKPaul
UKPaul's Avatar
Default Re: What headers work with angle plug heads? (SmokedTires)
Why are you changing the Sportsman II's for AFR's?
:cheers:
Old 02-17-2004, 11:46 AM
SmokedTires
St. Jude Donor '05
Default Re: What headers work with angle plug heads? (UKPaul)
I figured I'd get more $ for my old engine with it complete vs trying to sell the parts. I'm building a completely new engine so I won't be using anything from the old one. The reason I went with the AFR's was the weight savings & I liked the idea of having heads that are CNC ported ;)
Old 02-17-2004, 12:06 PM
BSeery
BSeery's Avatar
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I am using the Hedman headers on my ZZ4 engine. They have ceramic coating and the collectors seem not to hang down as far as other brands. That's important if you have limited ground clearance.
Old 02-17-2004, 12:21 PM
markdtn
markdtn's Avatar
Default Re: What headers work with angle plug heads? (BSeery)
Stock C4 TPI "shorty header" manifolds should work fine on angle plugs. The TPI aluminum heads have angle plugs. They have a 2 1/2" outlet too.
Old 02-17-2004, 12:23 PM
verskel
verskel's Avatar
Also be sure to get the right wires with the 45-degree boots so they won't get 'fried' by the headers ! :eek:
Old 02-17-2004, 12:25 PM
SmokedTires
St. Jude Donor '05
Default Re: What headers work with angle plug heads? (markdtn)
You have to be careful that the bolt patterns are the same though, because I think they changed the passenger side towards the firewall in the early to mid 80's. Just something to keep in mind if you try mixing older heads with newer exhaust or vice versa ;)
Old 02-17-2004, 03:10 PM
markdtn
markdtn's Avatar
I think the offset pattern was mainly for the F-bodies. The C4 shorties are the same pattern right and left.
Old 02-18-2004, 07:29 AM
UKPaul
UKPaul's Avatar
I figured I'd get more $ for my old engine with it complete vs trying to sell the parts. I'm building a completely new engine so I won't be using anything from the old one. The reason I went with the .....
Thanks Mike. Reason I asked is that'll (hopefully) be ordering some AFR's soon & a mate has just bought some Sportsman II's. I was wondering why you'd replace a good set of Sportmans with AFR's. I'd hate to think that my mate would regret his decision & wish that he'd got AFR's instead, especially if I turned up at the pub with some! :lol:
Back on topic: I've been told that my Dynomax ceramic coated Headers will fit angled plug AFR heads with no problems.
:cheers:
To What headers work with angle plug heads?
Quick Reply: What headers work with angle plug heads?
